9.7 SCR, D1SC, with 59cc heads?
Old Sep 27, 2010 | 07:43 PM
candlelit's Avatar
Default 9.7 SCR, D1SC, with 59cc heads?
Hey FI group! Quick question and hoping to find a few quick replies (looking at buying some new heads). If I were to buy a 243 head (64cc stock) that is milled .040 and ran this on about 14 lbs of boost, would I be able to prevent the heads from lifting or would the deck be too thin? Thanks.
edit: forgot to mention, the engine will stay N/A for probably 8-12 months, at least
Old Sep 27, 2010 | 07:58 PM
candlelit's Avatar
well, I just found this...
https://ls1tech.com/forums/forced-in...lbs-boost.html
but still open for opinions 3 years later...
Old Sep 27, 2010 | 08:08 PM
dschmittie1's Avatar
I am about 9.9:1 CR but with a non milled 243 head. IF you don't go crazy milling them I think you should be fine and not push water
Old Sep 27, 2010 | 08:13 PM
JAX04's Avatar
off subject, schmitte, didnt you do your own porting??
Old Sep 27, 2010 | 08:17 PM
yes I did. I had a machine shop cut in the larger exhaust valve and I cleaned them up. Nothing major just hit all the important parts
Old Sep 27, 2010 | 08:18 PM
candlelit's Avatar
yeah. I got to reading that thread I posted above and I'm starting to think a head milled .040 is too much, unless I swap heads when the procharger build comes around. catch is these ported 243 heads I'm looking at buying are only $300 more than what I'll be putting into stock 243's without being ported.
Old Sep 27, 2010 | 08:21 PM
JAX04's Avatar
lol, thanks man, sorry OP, end of thread jack
Old Sep 27, 2010 | 08:42 PM
How much would you be buying them for. Need to remember that you will need different push rods also for a milled head that might not be able to be reused later. What would your CR be with a stock unmilled 243
Old Sep 27, 2010 | 09:18 PM
candlelit's Avatar
about $900. complete with dual springs, upgraded retainers, & all. I already have a set of dual springs however I have to buy a tool or pay someone to swap them over to a non-ported 243, plus the idea of getting the stock 243 milled just a bit (cleanup purposes & a little more cr). With an unmilled 243 my scr will be pretty close to 9.2. I know with the ported 243 I'd gain about 15-20rwhp over the non-ported 243, but with these heads I'd also gain another .47 in compression, which would help power obviously.
Old Sep 28, 2010 | 05:33 AM
Well I have about $800 in my 243 heads that includes the sodium filled intake valves, larger exhaust valves, machine work, springs and porting. IF I where you try and find a ported 5.3 head that will raise your compression and isn't milled.
If you motor is forged you really shouldn't have any issues running 10:1 CR and boost
Old Sep 29, 2010 | 05:46 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I think you'd be fine at 14 psi. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
