Stock Bottom End LS7 and 10 PSI?
Old Sep 30, 2010 | 08:41 PM
riggs's Avatar
Default Stock Bottom End LS7 and 10 PSI?
Has Anyone done it?
I'm making 600whp on a 3.8 pulley with the A&A V-3 T-Trim Blower (7 PSI, very conservative timing), just ordered a 3.4 pulley, and am curious to see how it will live @10-11 PSI.
I run 110/91 (50/50) octane mix, and will plan on a 11.2-11.5 A/F.
Have the Rev Limiter set to 6500, may even back it down a little....
Engine has never had the valve covers off....so to speak.
Curious on your thoughts....
Old Sep 30, 2010 | 08:45 PM
MR2liter's Avatar
Meth and a spot on tune are your best friends!!
Old Sep 30, 2010 | 08:49 PM
riggs's Avatar
Meth needed in addition to the 110?
I have no issue running straight race gas, this is just a weekend toy.
Not a huge fan of meth, as that's just one more thing to go wrong.
Old Oct 5, 2010 | 04:38 PM
riggs's Avatar
Wanted to bump this one final time....see if anyone had any experience...
Old Oct 5, 2010 | 04:48 PM
cracker's Avatar
Call A&A.
Old Oct 5, 2010 | 08:36 PM
charlie_gonzales's Avatar
Tuned in for results...sounds nice
Old Oct 5, 2010 | 08:47 PM
clint195's Avatar
Ask Rodney at RPM transmission he is at 15psi. On a completly stock engine never had the valve covers off. Making 689 rwhp thru an auto swapped Z06.
Here is a nice little read on his car.
http://www.gmhightechperformance.com...z06/index.html
First off, let's discuss the engine combination. "The car has a completely stock [LS7] engine, never even had the valve covers off!" OK, well that was easy. Moving forward in the engine bay, we have the real secret to the horsepower, a Procharger D-1SC supercharger system that has been tweaked to work flawlessly run after run. For maximum boost, RPM installed a Cartek flip drive and 8-rib Innovators West crank damper, which brings boost in at 15 psi, enough air to lay down over 689-rear-wheel horsepower. Helping expel all of that air, Rodney relies on a set of Kooks 2-inch long-tube headers, which feed a 3-inch X-pipe and a set of B&B bullet mufflers. And, that's it for power
Old Oct 5, 2010 | 09:35 PM
riggs's Avatar
I'd love to know what RPM he is shifting at? And how much timing he is running @15?....
Old Oct 6, 2010 | 10:05 AM
chopperloco's Avatar
...keep in mind it is an auto conversion...
Old Oct 6, 2010 | 10:32 AM
Detroitmuscle's Avatar
he also has a hell of a tuner
