2 step help.
To build boost in an auto you need to add timing, which means more torque and more problems holding. Looser converter and a two step activated below the stall point might work to build boost on the line.
Your converter sound WAY too tight if it only stalls to 1800.
the converter i have is suppose to be a fti 3600 nitrous converter. i thought it was going to be a little tight for my set up but not this bad.
