370 vs 347
Old 10-17-2010, 07:01 PM
LSXFORMULA99's Avatar
Default 370 vs 347
In the process of starting engine build for my procharger.
My stock block is ok so i was leaning toward rods n pistons for it. Some guys have said the 370 would be worth the extra money...what you guys think
switching to a th400 w/brake
Old 10-17-2010, 07:09 PM
blue00ZZleeper's Avatar
I was orginially going to build a forged 347 but endup coming across some cash so I build a LQ4 370. What are your goals? A P1 is going to huff out pretty quick on a 370. A 347 might be a better choice for your build.
Old 10-17-2010, 07:17 PM
i want to build for the future. i dont want to keep the p1 much longer. would like a f1
Old 10-17-2010, 07:26 PM
killaxtranz's Avatar
if you go f1 a iron block has more plus's then aluminum. you can get quite a bit more hp and not have to worry. aluminum blocks have problems with head gaskets and handling over 750hp.
Old 10-17-2010, 07:31 PM
what kind of specs for custom cam. going with victor jr and prolly 243 or 317 heads. valve relief pistons
rotacoupe95's Avatar
I think if u could sell the 346 to make up the difference to get the lq4 I would say yes but the if cars in the 8s with 347 so it all depends on how fast u want to go...
Old 10-17-2010, 07:35 PM
im shooting for 9s...
RS_SS69's Avatar
Go 317 heads much better for boost, if you dont have a good set let me know I have a set ill sell cheap.
Old 10-17-2010, 07:38 PM
how much
Old 10-17-2010, 07:40 PM
I run stage 3 LS6 heads and just dropped the compression in the pistons. If your looking at going with a different blower, I'd go with the 370. I have a custom cam for my 370 as well. 9's with a good trans/ suspention setup shouldnt be to hard.
Old 10-17-2010, 07:49 PM
Just remember the The added 100 pounds with the iron block but if weighs not a concerned then its not a big deal but if your just looking for 9s then I would just go with the 347
Old 10-17-2010, 08:04 PM
ok cool. its going to be a while till i change blowers. i am wanting to go with a good size custom blower cam with valve relief pistons..what kind of specs are you guys running?
Old 10-17-2010, 08:30 PM
I wouldnt run my cam in a 347 but for a 370 its good. 235int/243exh .620/.623 lift 115lsa
Old 10-17-2010, 08:50 PM
not bad. hows pvc with it
Old 10-17-2010, 08:53 PM
Havent got it running yet. Cam is just a tad more agressive then the EPP or Brutespeed cam. I kinda went off that cam for a basis cause they seem to do very well.
Old 10-17-2010, 08:57 PM
yeah i thought about the epp cam but figure a custom grind might be better
Old 10-17-2010, 09:22 PM
Bingo...thats where my cam came from lol
Old 10-17-2010, 10:41 PM
93camaro_zzz's Avatar
This might be just opinion, but when I swapped from 346 to 370LQ9, the first main thing I noticed was the 370 sounded alot throatier, and generally more bad ***. I cant lie, the 370ci is an awesome sounding motor!
Old 10-18-2010, 12:26 AM
RS_SS69's Avatar
Originally Posted by LSXFORMULA99
how much
$150 shipped, have 17k miles on them.
Old 10-18-2010, 01:37 PM
98LSZ28's Avatar
^ if he dont buy those heads, i will. im gonna be talkin to him in about a half hour on lunch break and ill ask if he wants them...i live a few minutes from him and helped him pull his motor out. but for sure if he doesnt want them ill take em! lol
Quick Reply: 370 vs 347
