370 w/S91 spooling question
Old Oct 19, 2010 | 08:52 AM
ALTRDTA's Avatar
Default 370 w/S91 spooling question
So I got my car running finally and we went out and got her tuned in for the most part on the 7psi spring. The thing that I am curious about is when do people with this setup normally start spooling their turbo? My car isn't starting to spool til somewhere around 4800 rpm, maybe a little higher. It is a little rich right now but not any richer then 11.2ish. I've been questioning that the car is running only on 7 cylinders since out of boost the engine is pretty gutless. The engine was built by LME and has ETP 245cc heads, 8.5:1 compression, with a ported and polished Victor jr. intake/Nickwilliams 90mm throttle body. The turbo kit is one I got from OFI, so it's a tubular header design. Any info would be great. Thanks!
Old Oct 19, 2010 | 09:08 AM
hellbents10's Avatar
LS1Tech Sponsor
What kind of timing do you have coming into boost? What is AFR coming into boost and at lower boost?
Also with out a boost controller or bigger waste gate spring the gate will be open slightly at low boost making it come in slower.
Old Oct 19, 2010 | 09:15 AM
turbo'd stang's Avatar
Whats the AR on the turbo and how much timing?
Old Oct 19, 2010 | 09:23 AM
ALTRDTA's Avatar
16* timing and I just got off the phone with my brother who is the tuner and he said the AFR was actually High 10's to low 11's in boost, and low 13's high 12's out of boost. He said we are obviously running rich, but even with leaning it out I don't think it's possible to drop it 1500-2000rpms on the spool. There was a guy on here with a 408 (yes, i know a bigger engine. But still) that was starting to spool his at 2700 rpms...
1.32 A/R
Old Oct 19, 2010 | 10:17 AM
Mike454SS's Avatar
If it was only running on 7 cylinders it'd feel shitty (not just a lack of power, but not smooth...like a really bad misfire).
Old Oct 19, 2010 | 10:18 AM
Try adding 10* of timing coming into boost, as it hits a few pounds, pull the timing back out.
Throw CO2 on top of the gates too. they could be leaking
Old Oct 19, 2010 | 02:11 PM
Zombie's Avatar
You should probably have around 25-35 degrees of timing up to 1-2 psi of boost and then start to pulling it out. Something you have to experiment with to find what works best.
A 1.32 a/r isn't exactly a small hotside either.
Old Oct 19, 2010 | 02:30 PM
Sweet_SS's Avatar
You need to keep in mind that 8.5:1 is alot lower than 10.5 (I believe is stock) and will change your spool rpm. The idea of lower compression is to drop detonation...being able to run more boost than a higher compression motor. Also, the turbo's a/r will drastically change spool too. To big will make it laggy, but will make more power. On the other hand, to small and it will spool quick but make less power. I ran a GT4294 (70.1mm) on my 4 cylinder with a .98 a/r and it didn't see full boost until 6800rpm shifting at 9,000. Compression was 9.0:1. But then again, were talking about a 71mm on a 4cylinder vs a 90mm V8. Is your motor stock? You could be pushing the limit with a stock cube motor.
Old Oct 19, 2010 | 02:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
AF and timing are two elements you can change. You wouldn't want 16 degrees of timing off idle to when you first see boost.... You'd want more than that.
Old Oct 19, 2010 | 03:45 PM
ALTRDTA's Avatar
It doesn't seem to feel at all that way, just something I thought might be possible with the difference in afr from one bank to the other at times, then also the slow spool, and lack of power.
We will do that with the timing. As far as c02 on the gates. I guess we could try it, but next time I think we'll just hook the EBC up and work with that. Thanks for the advice!
Thanks for the reassurance on the timing. We'll bump that up on our next tuning session!
The engine is not stock in any way. Fully forged bottom end and aftermarket valve train/heads.
Good to know! Thanks a lot guys. We have been worried because I've read how much these LS engines don't hold up to a lot of timing and boost. Also, it's showing a lot of knock as it is already for some reason.
Thanks for all the replies guys! I have also been curious as to why at idle the Afr's from one bank to the other seem to be about 1.0 different at times (one side 13.8ish and the other 12.8 to 13.0ish. I have a fast dual wideband sensor on each bank. I am going to pull the plugs tomorrow to see if it has any signs of not firing on one of the cylinders. But at this point, maybe how rich it's running, and how low of timing we have, we might be able to get a good bit of spool at a lower rpm.
Old Oct 19, 2010 | 03:56 PM
FasTimeSS's Avatar
im having the same problem on my pt88/346ci i was hoping for maybe a boost leak but we are going to mess with the springs tormw on the wastegate
Old Oct 20, 2010 | 05:29 PM
99bluefirebird's Avatar
small engine, big turbo = lag
Old Oct 21, 2010 | 12:25 AM
ALTRDTA's Avatar
You're a genius!
Old Oct 21, 2010 | 09:07 AM
Gonoma's Avatar
HAHA! was thinking the same thing
Old Oct 21, 2010 | 04:12 PM
98Z28CobraKiller's Avatar
Restricted User
That is a horribly miss matched combo IMO for anything other than max effort. You got a lazy intake on over sized heads with real low compression and a big exhaust housing.
Old Oct 21, 2010 | 06:15 PM
ALTRDTA's Avatar
So you are saying that it's gonna be A dog at any given time other then Full throttle in boost?
Old Oct 21, 2010 | 06:43 PM
Gonoma's Avatar
ever looked into getting a quick spool valve?
Old Oct 21, 2010 | 08:43 PM
LASTLS1's Avatar
6 Second Club Moderator
I think it will be fine if you add timing and lean it out a bunch.
Old Oct 21, 2010 | 09:13 PM
Zombie's Avatar
No divided housings are available for anything bigger than the BW series turbos according to Forced Inductions.
Old Oct 21, 2010 | 11:36 PM
ALTRDTA's Avatar
I actually lied though. I need to get more specifics from my brother before I go and spout off on a thread here. Apparently the timing is at 24degrees until it goes into boost and then it ramps down to 16degrees. We are doing the tune/break in on the street and we're being pretty conservative with the tune to keep it safe and easier on the engine.
