1k hp guys help on set up
Old Oct 20, 2010 | 06:09 PM
xfactor_pitbulls's Avatar
Originally Posted by 98Z28CobraKiller
I ran my 8.9 on the stock 98 pcm but I was fudging the fuel. With a 2000 PCM, you shouldn't have a problem. Switching to the BS3 would be a mistake for sure. You would lose resolution and alot of scanning capabilities and like I mentioned, your gauges. Unless you piggy back the stock pcm and then it's just a clusterfuck.
I am putting together a similar setup and haven't nailed down the injectors. But the FIC high impedance seem to have good feedback. I was also looking at running the AEM controller on top of the PCM for 2 step, ease of tuning, etc. Opinions on these for our situation?
Old Oct 20, 2010 | 06:22 PM
Meemperor's Avatar
http://www.racetronix.biz/itemdesc.a...=01D144x-8&Tp=
along with
http://www.racetronix.biz/customkiti...c=ICS-8AEM&eq=
Plug and play with your stock PCM and you could always go to 120#'s. 160's are on the large side for 1K whp in a V8! That harness is key, saves a couple hours of wiring. I hate wiring crap like that
There's no reason to go to a stand alone with a GM car especially if it's going to be a street car. Also I'd suggest converting to a new style ZR1 maf and use a MAF tune. With that set up your car will run much, MUCH smoother with a good tuner and actually be drivable around town.
Old Oct 20, 2010 | 08:14 PM
TurboAv's Avatar
Slight Hijack: On E85 would the 120's be enough for 1k HP? Or should I go 160's?
Old Oct 20, 2010 | 10:56 PM
98Z28CobraKiller's Avatar
Restricted User
I have the AEM in my car and not crazy about it. It does have some benefits like being plug and play ish and runs the stock cluster and has lots of inputs but it quarky. Little **** that will drive you insane until you've done it once. The software for reading the logs is poor at best as compared to stock PCM w/ EFI Live or HPTUners.
Old Oct 22, 2010 | 12:22 AM
lt1camaroman93's Avatar
Stock 99 ecu with a AEM driver box and some 160's. Picked up NIB 160's for $350 and we run the car on E85. Speed Inc tuned the car and its the quickest ET ever on a stock ecu if I'm not mistaken.
Old Oct 22, 2010 | 07:22 AM
bad6as's Avatar
whats your best et?
Old Oct 22, 2010 | 03:46 PM
gnx7's Avatar
I'm interested if the 120 high impd injectors will feed a 1000rwhp e85 turbo setup as well.
lt1camaroman93- how do those low impedance 160# units idle? Are they streetable if you wanted? Any plug fouling issues.....
