To O ring or not to O ring
My old man is building a twin turbo 427 GM performance LSX motor for our ( monaro ) your ( GTO ).
The question is we want to build it for about 20psi max boost.
Should we get it O-ringed just to be safe or do we just use cometic MLS steel shim type head gaskets?
Engine parts so far.
GMPP LSX Block
GMPP LSX Heads ( 65cc chambers )
Dragon slayer crank
wiseco pistons.( dummied up at .020 down the bore)
FULL ARP STUDS in all holes top and bottom lol.........
SO SHOULD WE O/RING OR NOT O/RING????????????????
For thos that have boosted one of these things ? have you had any problems so far?
Any help would be great what are your thoughts??????
Thanks in advance regards Paul cheers
http://www.aseturbo.com/HOLDEN/VT-VZ...0/prod_95.html
also using a fast 102 mm intake manifold and throttle body
at least get them to upsize the exhaust housing ARs on those turbos or you'll be chocking / falling over at the top end.
And while your at it get a bigger intercooler 600x300x100.
Muilti layer steel gaskets should be fine.
