procharger install help
Old Oct 24, 2010 | 12:21 AM
dwnshft82's Avatar
Default procharger install help
i am installing a p1sc on my 99ls1 and have a few questions
1 do i need to do anything with my egr system
2 i am using a front mount intercooler and a mas air tune is there a certain distance i should put the mass air from the throttle body
3 do i need a treated intake air temp sensor and dos anyone have a part number
4 should i put the surge valve before or after the intercooler
i am sure their will be more things that i run into during my build any help with thees issue will be much appreciated
Old Oct 24, 2010 | 12:35 AM
Ericmck2000's Avatar
Im assuming your not using a kit...
Old Oct 24, 2010 | 01:29 AM
dwnshft82's Avatar
that is correct i am using a p1sc with 6 rib pulley setup and a eBay front mount intercooler and a standerd procharger surge valve trying four 8 pounds
Old Oct 24, 2010 | 09:53 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://www.google.com/url?sa=t&sourc..._YG7Iw&cad=rja
This older copy of the ProCharger installation manual will help you out.
I haven't noticed a difference in the placement of the maf.
Use the IAT Sensor SU107 for your front mount intercooler kit.
The preferred location for the bypass valve is before the intercooler, as it will keep heat out of the intercooler during part throttle use. This is not always possible, and you sometimes have to install the bypass valve after the intercooler. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 24, 2010 | 08:48 PM
dwnshft82's Avatar
thanks four all the help bob you have a great rep four a reason
Old Oct 24, 2010 | 09:02 PM
LS1Tech Sponsor
Thanks, I really appreciate it! Bob
__________________
