How much boost on this shortblock?
Old Feb 1, 2004 | 11:59 AM
Scoobie's Avatar
Default How much boost on this shortblock?
Hi guys, ive got a set of LS6 heads over at absolute that hes going to port for me along with an LS6 intake and one of his new 80mm TB's. I just need to tell him what stage and they are done. Problem is i cant decide if i want to build an ALL BORE 387 application or do this
Polished & Magnafluxed Stock Crank
· Diamond Forged Pistons / Flat Tops Or Dish
· Diamond 4130 Chromemoly Wrist Pins
· Diamond Proselect Ring Set / File Fit
· Eagle H Beam Connecting Rods
· Federal Mogul 152m Main Bearings
· Clevite Cb663h Connecting Rod Bearings
· Arp Main Studs
· Blueprinted & Fully Balanced
· Assembled
Which will run me around 2,700 vs the 6K for the 387.
What i want is the most reliable way to 500 RWHP.
Now, do you guys recommend i achieve this by buidling up my 346 like above and doing a blower, or going with the 387 build up. The cost will be about the same because the 387 will need the bigger stage 3 heads, and the blower will make up the 3k dollar difference in price between blocks. Im thinking i have more potential for even great power with a blower. But will it be reliable. The car will be stree strip. I will drive it on the nice weekends and to work on fridays or something. So, in conclusion
If i do the 347 build up, are there any parts not mentioned above you think i will need.
How should i have the LS6 heads ported if i go the blower rout.
What Diamond Pistons should i run?
And lastly, how much power do you think i can safely make.
Thanks for your time
Scoobs
Old Feb 1, 2004 | 12:13 PM
mike m's Avatar
ok as a blower guy, i like the all motor aproach. You will wind up spending alot more $$$$ with fuel systems and drivetrain componants. Jay could get you right around 500 rwhp with a set of his stage 3 heads.
Old Feb 2, 2004 | 03:57 PM
BIGBOS's Avatar
Just make sure you get the final compression ratio to around 9:1.......
The bigger the CC in the head the better.......
I'm running 73cc chambers on my current setup.......TEA S2 5.7L heads.......
