Rocker arm question
Old Oct 29, 2010 | 04:39 PM
RNation0001's Avatar
Default Rocker arm question
Ok I have a ls9 cam and it has about 560 lift. Would it be worth while to get 1.8 rockers to take my lift to round .600 ?
Iron block ls1
Diamond flattops
Compstar rods
Stock crank
317 heads
Comp ratio around 9.5 to 1
Prolly run a t76 master power or t70 open to opinions
Old Oct 30, 2010 | 08:47 AM
Anyone
Old Oct 30, 2010 | 10:33 AM
RedHotG8's Avatar
As long as there's not a clearance problem and the valve springs don't bottom out you will gain more power.
Old Oct 30, 2010 | 12:02 PM
BadgeZ28's Avatar
Different ratio rocker arms can add power, but consider the cost. A half pound more boost will make more power.
Old Oct 30, 2010 | 04:05 PM
well theres a set on here right now for a little over 300 so thats my question i guess would it be better to get them and if i did what kind of hp difference would it make. if i can go a half pound more boost and get more power its not worth it for me
