what pulleys for 8 psi procharger?
Old Nov 4, 2010 | 06:26 PM
jattgunman's Avatar
Default what pulleys for 8 psi procharger?
Do you guys know what pulley I need to achieve 8 psi of boost on my 2001
camaro ss? I've searched and searched but it's hard to find out which ones
to order...So 6 rib what crank and blower pulley will achieve 8 psi? I'm about
75 ft above sea level(sacramento,ca)
Old Nov 4, 2010 | 07:13 PM
02LS1ram's Avatar
I-forget the crank pulley size but the blower depending what u got d1/p1 would be a 3.8
Old Nov 5, 2010 | 02:18 AM
jattgunman's Avatar
oops! forgot to mention it is a p1sc
Old Nov 5, 2010 | 02:34 PM
jattgunman's Avatar
any one? is 8 psi too much for a 6 rib set up?? I'm thinking I need the 6"(5.8) crank and possibly a 3" pulley? but i've been told 3.8" also
Old Nov 5, 2010 | 03:16 PM
MadIceV8's Avatar
Customizing Director
6" Crank and 3.4" Blower pulley on a P1SC-1 should net you 7psi on a stock car.
Old Nov 5, 2010 | 03:58 PM
jattgunman's Avatar
I have a 3.2" blower pulley already, would that produce too much boost with a 6 inch crank?
Old Nov 6, 2010 | 05:52 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The 3.2 should be about perfect for 8 psi. With a good tune 8 psi is what I recommend going with. Bob
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 7, 2010 | 01:52 PM
youngrigo's Avatar
I have a 3.0 with mods in sig and a 2002+ ls6 cam and make 9psi
