HELP fuel RETURN LINE OR NOT!!, hobbs switch ???
ok so im gonna get my 99 fbody procharger setup going...couple questions...
i have a lonnies perf. twin pump kit... with boost ref. regulator..
??? 1 DO i need to run a return line for the fuel????? or is the way its setupfrom factory fine..
??? 2 Going to run hobbs switch to activate 2nd fuel pump.. running 8-9lbs of boost. when should it activate ##lbs of boost, any recommendations on the switch...
??? 3 any chance the map sensor could get pushed out of the intake when car see's boost, any concerns there or will everything be fine!!
