Procharger BOV
Old Nov 17, 2010 | 04:59 PM
qc97z's Avatar
^^ under engine idle/no boost, the bypass valve will always be expelling air (open condition). Under throttle (zero vacuum and boost) the bypass valve closes to route pressurized air into the motor. On a supercharged setup, the only exposed part of the induction system under vacuum at all times is the inlet side of the supercharger.
