Start with the heart... teaser
Old Nov 22, 2010 | 01:13 PM
  #41
Fireball's Avatar
we saw crank flex on the center mains on my 366...callies 3.622 stroke, aluminum block and aluminum rods...
Originally Posted by AES Racing
I'd be more concerned with crank flex if it was Nitrous, LSX block with Steel rods.
Aluminum block, aluminum rods, lot of give in the system.
Old Nov 22, 2010 | 01:21 PM
  #42
longrange4u's Avatar
Originally Posted by Phil99vette
From the list of the top shelf items in the build, aluminum rods, tall deck, badass Mast heads, it sounds like your going to make a TON of power... Honestly, the motor sounds like a 2000hp+ combo. Anything over 1600-1700hp, with a 4.250 stroke, I'd be running a Billet CCW crank.
Yea those are the goals for the motor.. Ok, will talk to Fraiser and the AES team more on this.
Old Nov 22, 2010 | 01:24 PM
  #43
Phil99vette's Avatar
7 Second Club
For a 2000hp setup with a 4.250" crank, you better have a Billet CCW crank. A couple hits with a non-CCW crank will wear out the main bearings from the flexing. #3 will wear quick and #2 and #4 will wear with the inner edges seeing the most abuse. The outter bearings #1 and #5 will appear fine.
Old Nov 22, 2010 | 01:35 PM
  #44
427's Avatar
427
Depends on the power you want to achieve. The stroke you chose weakens the crank naturally by the 1/8 inch of material in the cross section, this will cause the crank to deflect more than the 4 inch stroke stuff. Being a high cam build with stock type cam the room is available for the BB chevy rod pin to get .050 of that overlap back and give the crank as much strength as possible. When you look at the bearings out of this type of engine you can see the crank is moving like a wet noodle, this is reduced tremendously with the center counterweights. The downside is cost and time for the part to be made, upside is the part can be speced for added strength where you need it.
Kurt
Kurt, so are you saying that the crank we are using should be a billet center counterweight crank? What is the difference in durability / power handeling?
Old Nov 24, 2010 | 12:22 AM
  #45
Kurt... Awesome feedback. Thanks man... your rep is achieved through the build of some amazing cars. I appreciate it. You talk about the Stroke.. could you elaborate on that more?
Old Nov 24, 2010 | 07:06 AM
  #46
CarsandWomen's Avatar
just a heads up, I feel like, well, I am, watching masters at work and thoroughly enjoying it. So please continue
Old Nov 24, 2010 | 08:46 AM
  #47
427's Avatar
427
I attached a picture of a drawing it looks like my kid did!! The circle in the center is the rod diameter of the stock engine (2.1), the outer circles are the diameter of the main (2.559). I did 4 different strokes so you can see the cross section left with different strokes. As that cross section is reduced the basic crank can be bent with less effort, and by ci added the power cycle is getting stronger with the larger strokes as the crank gets weaker. The better materials help stop this from becoming catastrophicand and it may help explain why some smaller engines get by without 4340 cranks and center weights. One other thing that makes this engine tougher for crank guys is the basic design being short for use in front wheel drive cars, this shortens the crank and narrows the cheek area where the overlap happens.
Kurt
Old Nov 26, 2010 | 11:11 AM
  #48
Fraser... chime in here too. Ok, so I get that the further the stroke is from the main.. the more inertia in generates thus putting more stress on the crank and the bearings.
The counterweights offset some of that stress caused do the the inertia.
Ok so for a ~2000HP build... how often am I going to have to tear the engine apart? Sounds like replacing bearings will be somewhat common? What other parts will wear quickly?
Old Nov 27, 2010 | 11:22 AM
  #49
AES Racing's Avatar
Far as inertia goes, 8 counterweight crankshaft has more inertia, inertia is the resistance to change motion, heavier crankshaft MMOI goes up.
Kurt's post relates to overlap of main and rod journals, more cross section that intersects between main and rod journals, naturally stronger, explains why a stock iron crankshaft is strong, it has .519" of journal overlap. Less overlap has more stress on the crankshaft.
As crankshaft flexes, it will wear the bearings.
The aluminum rods we typically swap out every 60-90 runs, for most people that is 1 racing season.
Based on other builds we do, i'd expect replacing, rings, rods, bearings and gaskets every year.
Old Nov 28, 2010 | 10:11 PM
  #50
So the larger stroke crankshaft has reduced overlap and thus more stress on the crank?
Old Nov 28, 2010 | 11:31 PM
  #51
kmracer's Avatar
take a 10 pound weight, hold it to your chest, and spin. take the same weight, hold it at arm length, and spin. what exhibits more inertial force?
thats a simple explanation of what you're doing to the inside of your engine, not that a longer stroke is a bad thing, or it cant work. i'd rather have a 7000 rpm 4.25" stroke motor than a motor with a 3.4" stroke that turns 8500 rpm...
