HELP ME PICK A SET OF HEADS! (AFR vs Trickflow)
Old Nov 18, 2010 | 06:51 PM
EvilStang's Avatar
STF Veteran
Default HELP ME PICK A SET OF HEADS! (AFR vs Trickflow)
I was originally going to go with a set of L92's for my build but have scraped that option. I am now able to go with either Afr's or trickflows. If you had to choose which would you go with and why? which seems to have the best performance under boost? this is a Lq4 bottom end
Old Nov 18, 2010 | 08:09 PM
98Z28CobraKiller's Avatar
Restricted User
I'd go with a set of the new AFR230's. You can still use your stock rockers with the AFR's.
Old Nov 19, 2010 | 05:06 PM
nasty2000z28's Avatar
brian tooley is the guy you need to ask this. he'll give you the answers you need. https://ls1tech.com/forums/member.php?u=7596
Old Nov 19, 2010 | 07:32 PM
sixpack_2_go's Avatar
i've been wondering the same thing myself
Old Nov 19, 2010 | 07:45 PM
NicD's Avatar
7 Second Club
If you speak to Brian Tooley he will say TFS since he works there and if you ask Tony Mamo he will tell you AFR since he works there so I'm not sure what would be accomplished by directly asking them. I personally would say AFR as they are a direct bolt on and you can run your stock rockers with them and they're more than enough head for what you are asking to do. I believe TFS recommends aftermarket rockers for their heads.
Old Nov 19, 2010 | 07:49 PM
Phil99vette's Avatar
7 Second Club
MAST 225s
Old Nov 19, 2010 | 09:48 PM
427's Avatar
427
I would vote for the 6 bolt version of the TFS 235, although both heads are great products.
Kurt
Old Nov 20, 2010 | 12:52 PM
BigRich954RR's Avatar
Kurt
plus both heads can run stock rocker but both heads should have roller rockers on them cause of the valve guides
Old Nov 20, 2010 | 01:10 PM
lt1773's Avatar
TFS 235 heads will need to run yella rockers,AFR do not need the yella rockers,ETP do not need yella rockers, Eledrbrock 245 do not need yella rockers
