Suggestions for my upcoming build?
Stock internal motor
228r cam (it's already in)
317 Heads (gotta sell my TEAs.)
".040 Headgaskets
Truck mani kit, hotside/coldside fabbed by a local shop
Precision 76mm turbo
Griffin Radiator
Notch the stock K member
Meth injection
Now here's my questions...
I have a walbro 255 FP in the car right now, am I going to need another fuel pump? How should I set up my fuel system?
What size wastegate should I go with, any brand recommendations?
BOV?? No idea what to get.
Injector size?
I am shooting for 650 on pump/meth, rev limiter set at 6400 RPMs.
What PN for the Griffin Rad?
What fans should I get to move the air through the rad?
Oh, and the car will be getting an SD tune.
What else am I forgetting? Thanks for the help guys.
".040 Headgaskets
Griffin Radiator
Meth injection
Injector size?
if you want to have a setup u can have peace of mind, and be able to up your HP in the future, run a -8 feed and use stock line as a return.
60mm jgs wastegate(u will need a big gate to get down to the low boost required for stock internals)
tial BOV
80# injectors
what "stock internals" is it?? ls1? lq9?
tial BOV
80# injectors
Should I just run the dual 255s straight out or should I hook it up to a hobbes switch to activate on boost?
Thanks for the advice on the big gate, I think it'll only need 8-10 lbs to get it to where it needs to be...
I still need to come by and take measurements off your pile so I know how far to cut and ****. Call me.
