k member question
Old Nov 26, 2010 | 01:22 AM
98Camarod's Avatar
Default k member question
What aftermarket k members out there, if any, allow you to use solid mounts? I need to have solid mounts so that my downpipe doesn't melt the mount.
Old Nov 26, 2010 | 07:21 AM
JaYZeig's Avatar
can try these solid engine mounts...will allow you to use your stock "k" member
http://www.spohn.net/shop/1998-2002-...or-Mounts.html
Old Nov 26, 2010 | 07:25 AM
dschmittie1's Avatar
shopn has the only k member that you can run solid mounts that I know of
Old Nov 26, 2010 | 11:46 AM
98Camarod's Avatar
Thanks
hows the fitment with this thing and how big of weight savings?
Old Nov 26, 2010 | 11:52 AM
I had one before swapping to a BMR Turbo K member. Fitment was great no issues there. not sure what the exact weight savings was
Old Nov 26, 2010 | 03:33 PM
CarsandWomen's Avatar
8 pounds I think, it also raises the motor a little bit. plenty of guys have said they didnt notice any extra vibration at all. Ive got them, just no install yet
Old Nov 26, 2010 | 03:55 PM
I think he was asking about the k member not the mounts. K member saves more like 20-25 lbs
most after market k members don't allow you to run a solid mount but the spohn k member does
Old Nov 26, 2010 | 04:35 PM
98Camarod's Avatar
Yea, I have the spohn solid mounts already on. I need to keep them. So if its the only one that lets you run them, then so be it.
Why did you switch to the turbo k member? Is there that much more room?
Old Nov 26, 2010 | 05:06 PM
ah ok, i see
Old Nov 26, 2010 | 05:46 PM
Broke EF's Avatar
Midwest Chassis!
Sean
Old Nov 26, 2010 | 05:50 PM
IWGF's Avatar
Originally Posted by Broke EF
Midwest Chassis!
Sean
Do you have one? I'm going w/ Eric whenever I decide to step up. Details on the piece? PM me if you'd like.
Old Nov 26, 2010 | 09:34 PM
xssive's Avatar
https://ls1tech.com/forums/parts-cla...or-mounts.html
Replaces your stock rubber mounts and works with any aftermarket k-member that uses stock mounts
Old Nov 26, 2010 | 09:58 PM
I had the spohn k member when I had the procharger on the car. No room to run a 4" down pipe with that k member. MUCH more room with the BMR turbo k member can easily run a 4" DP
Old Nov 26, 2010 | 10:03 PM
I_Need_Land's Avatar
how about 5"? im debtating buying the bmr turbo k member and running 5" out the back as opposed to 5" out the front fender..
Old Nov 26, 2010 | 10:27 PM
openboost's Avatar
am building a kit wish uses a stock k-member an a set of custom solid mounts that i build to run 4" down pipe and i can duplicate it, let me know if you want pics
Old Nov 27, 2010 | 03:48 AM
Broke EF's Avatar
I dont own an f-body, but the car I work on has one. What details are you looking for? It will clear a 5" downpipe on the passenger side no problem. You can see some pictures here.
https://ls1tech.com/forums/drag-raci...ld-thread.html
This was the last prototype / first production piece. I saw pics of a recent once and there were a couple of small changes.
Sean
Old Nov 27, 2010 | 06:24 AM
98Camarod's Avatar
do these mounts change the height of the motor any?
Old Nov 27, 2010 | 12:31 PM
Broke EF's Avatar
Midwest Chassis has a set of mounts that are similar. As far as I know they place the motor in the stock location. That is what we have on our car.
Sean
Old Nov 27, 2010 | 12:42 PM
xssive's Avatar
Nope, they place the motor in the same position as stock mounts. They are the same external dimensions, just solid
Old Nov 27, 2010 | 01:26 PM
98Camarod's Avatar
Sean
I don't see the k member or mounts on the site. Any link to pics and pricing?
