looking to learn from your experience d1sc install
Old Jan 2, 2011 | 10:42 PM
BLAKE 01 WS6's Avatar
My ATI balancer was very easy to put on and pin with the kit supplied from Bob. the pass side will be easy the drivers side required alot of hose trimming to get it to fit just right. Put the surge valve on last to keep it outta the way while installing the air inlet. It would prooly alos be easyer to go ahead and put the plastic boot on the air filter and set it on top of the drivers side intercooler before the j-tube is installed so you dont have to cram the filter in there. Also if you put the extra spal 9" fan like i did then i had to keep the shroud lifted all the way up to get the blower mounted, then drop it back down afterward.
Old Jan 2, 2011 | 10:46 PM
O and i found it easyer to do the drivers side tubing by working from the top down from the lid back to the intercooler. trimmed and connected the 3" to 2.5" reducer last that connected the j-tube to the I/C. also that 2.5" metal coupling needs to be put together and tightened before running it down under the fuse box. its really tight in that area. I popped the fuse box up and lifted it as much outta the way as i could for room to work.
Old Jan 2, 2011 | 10:49 PM
also the blower belt will be f-ing tight. i thought i was gonna knock my car off the jackstands to get it on. you must use the crank bolt to spin the motor to get it on. dont even try it the way procharger tells you. I wasted several hrs trying it their way before giving up and calling bob. i was actually afraid i was gonna break the belt it was sooooooo tight.
Old Jan 2, 2011 | 11:55 PM
cals400ex's Avatar
i have the sdce tensioner and my blower belt is set at the #15 mark they said it should be at. however, the best isn't that tight. it is probably comparable to the stock serpentine belt. i am not sure if this is right or not....
Old Jan 31, 2011 | 11:41 AM
All done with mine. Extremely happy with the outcome!!!! Thanks again to Bob at Brute speed and Mike at G-force.
Attached Thumbnails looking to learn from your experience d1sc install-dynoint.jpg
Old Jan 31, 2011 | 12:35 PM
sscamaroburn02's Avatar
Very good #'s. Get some pics and vids and let us see something.
Old Jan 31, 2011 | 01:10 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I did not think my procharger install was hard at all. I had it done in one day. First time took about 10-12 hours. I could now do it all in about 1/4 of the time if I had to do it again.
Old Jan 31, 2011 | 02:28 PM
luna123black's Avatar
nice # blake how much boost was that on and what else is done to the motor.
i wouldnt call it hard just a pain in the rear. i kept running into stupid little issues. like alt not fitting. my installs done but i wont drive the car in new england weather(looking at 20 more inches of snow by wendsday) so i wont get it to the tuner till about april. gives me time to install a new clutch and meth kit.
Old Jan 31, 2011 | 03:11 PM
7.5psi
Ls6 intake
Stock 241 heads with patriot dual gold springs, Gm MLS head gaskets ARP head studs
Lingenfelter GT2-3 cam
Longtube headers w/cutout after y pipe
Spec stage 3+ clutch w/billet flywheel
3" steel chromemoly driveshaft
mosler 9" with 4.11's
17x11 tt2's with 315 MT dr's
Old Jan 31, 2011 | 03:25 PM
LS1RedZ's Avatar
Originally Posted by BLAKE 01 WS6
7.5psi
Ls6 intake
Nice numbers man! Now get you some pistons and rods and turn it up! haha
Old Jan 31, 2011 | 09:39 PM
I got the dyno vid in HD video just gotta get it onto my computer then here. My girls have been taking turns being sick and ive had to work alot.
Old Jan 31, 2011 | 09:41 PM
  #32
thanks, yeah gotta let the pocket book cool off a while after that procharger kit. Hopefully the shortblock will hold on for a little while. I told mike to tune it safe vs max effort so we will see.
Old Mar 20, 2011 | 01:16 PM
  #33
ramairetransam's Avatar
nice info , im buying a used kit and have been looking all around for info on this .
I could use some tips too .
Old Nov 14, 2011 | 12:55 AM
  #34
I8UR4RD's Avatar
Please read this thread, it's about an F-BODY PROCHARGER kit. You wouldnt even get all the parts out of the box, unwrapped, and sorted out in an hour and a half. I was just venting off a little frustration with the lack of room to work on these cars not really the procharger kit itself, although the instructions I feel could be a lot better than they are. Nothing just slides right in with this thing.
that was ****** hilarious because itz true..haha.
Old Nov 14, 2011 | 01:11 PM
  #35
One more thing is my single 255 pump and Hotwire kit would not keep up, fuel pressure was dropping under boost. Switched to Lonnie's duals and it's running great now. Lonnie's kit is top notch and easy install. Just waiting on some nice cool air to play at the track.
Old Nov 17, 2011 | 07:24 AM
  #36
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Question
That is weird that you had fuel pressure problems with the 255 pump/Hotwire kit at 7.5 psi with your combination. I haven't ever seen that before, I'll bet you had either a bad pump or a clogged fuel filter, etc. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 17, 2011 | 10:17 PM
  #37
babygirl02's Avatar
Default can u rub a 10 rib belt
Can u use a 10 rib belt on ds 1 procharger
Old Nov 18, 2011 | 07:44 AM
  #38
LS1Tech Sponsor
ProCharger does not offer a 10 rib belt set-up. The Aster bracket is the best way to eliminate belt slippage problems, here is a link to it. http://shop.brutespeed.com/Aster-Aut...er-Bracket.htm Bob
__________________
Old Nov 18, 2011 | 08:06 AM
  #39
The Alchemist's Avatar
UNDER PRESSURE MOD
I know it's an old thread, but everyone who wondered if they really needed to pin the crank, the answer is YES! You absolutely need to. I was lucky enough to find my bolt just loose and not gone and I only have a few blasts on the car.
Old Nov 18, 2011 | 08:37 PM
  #40
Z-28's Avatar
Whats the most horse power to get out of stock fuel lines? I have twin 255 pumps but a stock line and wanting to up my boost/power.
