Having problem with rwhp‏
Old Nov 28, 2010 | 09:24 PM
NAVY's Avatar
Default Having problem with rwhp‏
Hi thereI have my camaro m6 with f1c
Engine compression is 9.1
Stroke 408 cid
Afr heads 225 72cc
Running 16 psi
What should expect ?
What is the minimum number for rwhp and trq
And whats the maximum number ?
thanks
Old Nov 28, 2010 | 09:30 PM
OUTLAWZ RACING's Avatar
1000 max on 20+ , 16-18 800-900 min considering everthing is in order.
Old Nov 29, 2010 | 03:37 PM
NAVY's Avatar
i think i have mistake in my car 655 rwhp ,I will chack boost in the dyno 5500 rpm 10 psi thin the boost is Jump to 16 psi .
this information my engine
F1C ProCharger SDEC 16 psi
ls1 Aluminum block 4.030
wiseco piston 4.030 - 20cc
Lunati rods 6.125
eagle 4" Crankshafts
AFR heads 225 72cc
Cometic MLS Cylinder Head Gasket, LS1 Engine, .051 thickness, 4.030 bore
cammotion cam 230 - 240 590 600 114 lsa
m6 Transmission
SPEC Clutch, Stage 5 3.43 gear
Bosch Injectors 79 High Impedance
3 bar map sensor 43 fuel flow in idel and 62 fuel flow in high RPM ( 6500 RPM )
any advice pls
thanks
navy
Old Nov 29, 2010 | 10:36 PM
68 SS's Avatar
Weird I have never see your car around Kuwait, give me a call maybe I can help you out +965 6-507-6274 who is tuning it here? Dave
Old Nov 30, 2010 | 05:06 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Try making a run on the dyno without a filter on the inlet side and see if the boost and power jumps up. Just keep an eye on the air/fuel ratio! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 30, 2010 | 08:28 AM
lt1773's Avatar
you have to check your boost reference and make sure it is working proper condition
Old Dec 1, 2010 | 10:56 AM
NAVY's Avatar
i will remove the filter Same problem ?
Old Dec 1, 2010 | 11:58 PM
blue00ZZleeper's Avatar
How many degrees of timing? Does the tuner have the timing at like 4 degrees? lol. She should be making A LOT more power. It sounds like its in the tune. Was the boost pressure seen on the dyno or just a gauge in the car?
Old Dec 2, 2010 | 09:04 AM
lt1773's Avatar
what type of fuel are you running & what was the timing ???
Old Dec 2, 2010 | 11:17 AM
2001WS6Vert's Avatar
I'm confused. In your sig. it says 850 rwhp for your combo., what changed.
Old Dec 2, 2010 | 05:48 PM
FasTimeSS's Avatar
make sure u have a good wastegate that isnt leaking also check for boost leaks
Old Dec 5, 2010 | 04:26 PM
NAVY's Avatar
93
18 timing
i will chack there is no leaking in valve
Old Dec 6, 2010 | 06:36 AM
LS1Tech Sponsor
Question
I was wondering the same thing. Bob
__________________
Old Dec 8, 2010 | 12:11 PM
NAVY's Avatar
compression
befor 10.2cr now 9.1cr
Old Dec 8, 2010 | 11:29 PM
Lowering the compression will change the power...lower comp on same boost will make less power...it just has less chance of detonating. Any leaks on the BPV/BOV (whichever you have)? I dont have hp tuners or EFI live but if anyone has them maybe they can take a look at your tune. Do you run a wide band?
Old Dec 8, 2010 | 11:56 PM
Snyper's Avatar
....its a supercharger. Belt slip maybe?
Old Dec 12, 2010 | 10:56 AM
NAVY's Avatar
Is it possible to be belt i will be shorter the belt size 1325mm to 1320mm
