injector help
Old Nov 29, 2010 | 07:24 PM
Blue92coupe's Avatar
Default injector help
I was wondering if I could get some help on injector size for new setup before we go to dyno. Any help would be appreciated. thank you.
motor:
408 iron block
ported 317's
234/240 589/589 115
victor jr
76mm
big stuff 3 with 3 bar map
old setup was all the same on on stock 5.3 and had 60# injectors. any suggestions on setup and injectors would help. thanks again.
Old Nov 29, 2010 | 08:18 PM
mightyquickz28's Avatar
What is your HP goal? That will be a baseline factor for getting the injector sizing.
Here's one of many sites for calculating your injector requirements.
http://www.witchhunter.com/injectorcalc1.php4
motor:
408 iron block
ported 317's
234/240 589/589 115
victor jr
76mm
Old Nov 29, 2010 | 09:38 PM
Great thank you that helps alot. looks like im gonna need around some 98#ers.
