GTM turbo fabrication
cost would very greatly depending on how nice you want to go aka materials and such. 321 stainless, 304, etc. do you want a nice precision intercooler core with in house made sheetmetal end tanks. single turbo or twins. exhuast layout and material. wastegate/s bov etc etc etc.
to give you an idea we just did a turbo kit on a buick grand national. headers, crossover, flanges, all vbands, EGT's in each runner etc. all in 321 stainless. it was ~1800 for the material alone on the kit. no exhaust, intercooler piping etc. but thats the best of the best material
and certainly no offense to bad bird.
i have a gtm build manual but i can't remember if it comes with manifolds.
you just buy the u or j bends put the turbo where you want it, get your sharpie out ,fire up the chop saw ,set your mig to kill and get to work. i think you maybe overthinking the difficulty. keep each side as symetrical as you can and use some common sense with basic turbo concepts. i know you want something sweet that you might not see another in your area but if you do build a gtm then you must have some interest in the hands on part of auto building.
As for sizing, I was thinking smaller than 76, I am only looking for 7-9psi. Will a 58 not get me there?
As for an intercooler, it will need to be small.
As for intercooler(s) you can get creative in its placement as long as you have a good supply of cold air to it. Or you could run a water to air unit that would be more consistant but has more parts to fit into what is a tight area already.
I am thinking a single T70 tucked way back under the hatch (where the latch is in the below photo) with custom sheet metal covering the turbo. Sort of like this GTM used the covers to hide the piping. Note this GTM is also running meth on top of twin intercoolers.
BTW this photo will enlarge if clicked on, for some reason the others will not.
My opinion would be keep the manifolds and possibly look at porting them out to flow more. I fabed up a rear mount turbo on my camaro over the summer and it was rather easy in my opinion. As far as cost goes, it all depends on material choices as was already noted by other people. My whole build for a rear mount came in right around $2,500 for everything (including beer), But I did get a good package deal on my turbo, wastegate, and bov. So I think your $4-5,000 would get the job done if you do the work and look for package deals on the major components( turbo, bov, etc..) and still have money left over!
BOV........HKS $150.00
Wastegate......OBX 41mm or PCP 60mm (either) $200.00
intercooler......Ebay water to air kit $249.00
Manual boost controler........Hallman pro $75.00 or AEM Tru-boost $244.00
Mild steal piping w/6 flanges........... $350.00
Intercooler pipe kit ($100 each x2).......Ebay $200.00
Stock manifolds. $0
Modified stock exhaust $0
Fuel pump................. Walbro 255 $198.75
60Lbs injectors........... Siemens Deka Mototron $340.00
Spark plugs.............$25.00 (which ones should I use)?
Total cost $2350-$2650.............What am I missing?
Wastegate......OBX 41mm or PCP 60mm (either) $200.00it is recommended to use name brand proven parts. how about JGS or Tial?
Mild steal piping w/6 flanges........... $350.00Stainless is a better material. do it once. do it right
Intercooler pipe kit ($100 each x2).......Ebay $200.00 that's alot for piping. if you pm me i can send you a link for cheap aluminum piping that is mandrel bent for alot cheaper
Stock manifolds. $0
Fuel pump................. Walbro 255 $198.75or two?
High flow rails......... New Pro $150.00
Total cost $2500-$2700.............What am I missing?
edited for ya bro.
