Procharged LS1 tuning issues
Old Dec 1, 2010 | 11:29 AM
DASSON's Avatar
Default Procharged LS1 tuning issues
I installed a P1SC twin intercooled kit on my 2001 SS. Great thing about this kit is that procharger sends you a tune for the car in a nice Diablo Sport tuner. Loaded the tune, and under heavy load/full throttle conditions the car runs great. When I'm just driving around town, the car runs a little rough, the best way I can describe it is that it "blips" lean every once in a while. I'm sure some of you know what I'm talking about, under soft acceleration it kinda feels like it's hiccuping a little. I have a wideband a/f guage in the car, so I know it's popping lean, but won't stay lean, "blip" is the only word I can think of right now. It also does this when I'm just on or off the throttle. Under a load, it's pouring the fuel to it, and is doing exactly what it's supposed to. The easiest thing to do is to get this car tuned, however I'm a little short on cash at the moment. The diablo programmer seems to have a lot of tunability to it, I was wondering does anyone have any suggestions as to where to start? I've tried 2 different mass airflow sensors, stock and aftermarket, and the problem doesn't change. This car has headers and full exhaust, no cats, and other than that is bone stock with the exception of the procharger kit.
Any suggestions would be great
Old Dec 1, 2010 | 11:37 AM
68 SS's Avatar
I have seen a gummed up throttle body cause this same situation may want to pull it and scrub it and the IAC port??
Old Dec 1, 2010 | 11:44 AM
DASSON's Avatar
I cleaned it real good when I had everything apart. I've never had a car with an a/f on it before, but that thing is jumping around like crazy. The only time it's steady is when the car is into the boost.
Old Dec 1, 2010 | 12:05 PM
BadgeZ28's Avatar
I monitor the cmd A/F ratio coming off the pm. I see 13.60 cold and 14.60 warm.
Old Dec 1, 2010 | 12:54 PM
slow67's Avatar
Gingervitis Addict
If its in closed loop it will bounce around from 14.3 to 15 ish all the time (narrowbands aren't accurate at stoich, only just above and just below, so the PCM always bounces around it).
Old Dec 1, 2010 | 01:06 PM
airforcemanss's Avatar
when you get it figured out...would you mind posting down the road if you havie any cooking issues down there? im assuming you have the 3.5 IC's?
so how does she feel even though the tune isn't spot on?
Old Dec 1, 2010 | 07:46 PM
DASSON's Avatar
Of course, I'll let you know. I upgraded to the 4 inch intercoolers, or 4.5's, I can't remember what the upgrade is, but they are huge. I must say, I'm running 5 pounds, but it screams. I'm VERY happy with it. It's just a pain to drive around town with this problem. Thanks for the suggestions, I will keep you posted.
Old Dec 2, 2010 | 05:32 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
They are 4.5" thick intercoolers. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Dec 2, 2010 | 07:37 PM
lifeisgood's Avatar
id be a lil concered about the lean issue.....dyno tune would be the best solution but, you said your short on cash, contact ATI....they were pretty helpful when i had my p1sc system
