Update on Red Dogg
Old Feb 5, 2004 | 01:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Update on Red Dogg
2/5/03
Car is shortly going to be moved to Alston Racing to have the existing 6 pt roll bar converted to a 10 pt cage. Also will be installing an angle design window net with the buckle style clip.
From there the car will be moved so that I can do the following:
-Install longer front wheel studs (Moser)
-Remove 4.11 gear and install either 3.50 or 3.70 gear
-Install beefier rear swaybar
-Clearance front calipers so I can remove the front spacers
-Paint front clip (VFN WS6 hood, 25 lbs bolton style)
-Reinstall carpeting
-Install drag seats or front drag brakes
Car will be going to the RT66/NHRA chassis certification day in March so I am trying to get it all done in time.
We will redyno the car sometime in March for the last time since I will be making slight revisions to the combination. This will be the fifth dyno session.
Here is the car right before I had it moved last week:
Attached Thumbnails Update on Red Dogg-zfirebirdrear.jpg   Update on Red Dogg-xcar1.jpg
Old Feb 5, 2004 | 01:58 PM
BIGBOS's Avatar
Good to see......just make sure they match that front clip, don't want it to look too red........
What type of swaybar are you using in the rear?
Old Feb 5, 2004 | 02:05 PM
LS1Tech Co-Founder
I have a stock one in the back right now.
I have not decided what I will run in the back yet.
Old Feb 5, 2004 | 02:08 PM
distortion_69's Avatar
When do we get to see the beast in action?
Peace,
Old Feb 5, 2004 | 02:22 PM
LS1Tech Co-Founder
When the tracks up here open up.
Old Feb 5, 2004 | 02:56 PM
ONEBADWS6's Avatar
Get the BMR drag bar John.
Old Feb 5, 2004 | 04:40 PM
BIGBOS's Avatar
How much do those good for, I still haven't upgraded that or my PHB, I think the drag bar is around 400ish if I remember correctly.....
Old Feb 5, 2004 | 04:57 PM
CHRISPY's Avatar
Good stuff!
Glad to see you nail the safety stuff down right
Old Feb 6, 2004 | 06:10 PM
niphilli's Avatar
Red Dodoublegizza is going to be one nasty 'some bitch
Better get the 'chute installed while you are at it
