keep the MPT 70, or go with TC76?
Old Dec 24, 2010 | 08:58 AM
  #41
1fast bird's Avatar
I've been in a truck with a mpt70 and it was instant spool with a 6.0. For the money it's hard to beat. If you want an easy to package, great power and decent spool then the tc76 is perfect. They are a few hundred more than the mpt unit but is worth it IMHO. I don't think you would be disappointed with either turbo......Unless you want to make more than 700hp, then the tc76 is the better choice.
I run the tc76's and love them. They are great little turbos and make more than enough power for me.
Old Dec 24, 2010 | 07:10 PM
  #42
crashly's Avatar
Originally Posted by rotary1307cc
Dr turbo can you upgrade a TC with the F1-68 to the GTS 75mm wheel?/
i believe the bearing housing of the TC / T series turbos is different to the mid frame turbo bearing housing, that supports the 75mm shaft ... the largest turbine wheel the tc / t series will support is the F1-68.
Old Dec 24, 2010 | 08:10 PM
  #43
rotary1307cc's Avatar
thanks for the info
Old Dec 29, 2010 | 04:45 AM
  #44
crashly's Avatar
thanks for the info
the presicion T4 ,pt stuff can take the 75mm turbine..
wonder if DrTurbo can do a custome turbonetics build ,in mid frame bearing housing, BUT sleeve bearing ????
im interested to know the cost ?
Old Dec 29, 2010 | 08:36 AM
  #45
oh boy, if its true, you and me both!
Old Dec 29, 2010 | 02:50 PM
  #46
Johnv's Avatar
Yes they can do a race cover for the TC series supposed to be good for an extra 120 hp airflow 3" outlet.
But your turbo has to go back to them to machine a backing plate to suit.
I'm pretty keen to get it done over our Winter, but havn't herd any real wourld results yet.....
perhaps Dr Turbo could chime in ...........
check this thread https://ls1tech.com/forums/forced-in...ade-price.html
Old Dec 29, 2010 | 03:02 PM
  #47
seems like the F1 turbine would be the big HP limiter, not the compressor with the small cover
Old Dec 29, 2010 | 04:33 PM
  #48
CarsandWomen's Avatar
well he did say in that thread that the upgrade is designed to sort of bridge the gap between the TC series and large frame turbos and also that they are made for 300 to 370 cube motors. So it prob would be for the 370 cube guys but the f168 is perfect for the 4.8, 5.3, and 5.7 guys. the 6.0 and 6.2's should prob just find a larger exhaust housing and be fine
