twin turbo oil lines
Old Dec 11, 2010 | 08:07 PM
Novaray64's Avatar
Default twin turbo oil lines
were is the best place to get oil for a twin turbo setup on a lq4 block
Old Dec 11, 2010 | 08:28 PM
LS1NOVA's Avatar
drill and tap the plate above the oil filter.
Old Dec 11, 2010 | 08:36 PM
Novaray64's Avatar
is it possible to get oil from were the factory oil pressure sensor is or the plugs in the side of the block. I am already planning to drill and tap the oil cooler bolck off plate for the oil pressure guage. I am trying not to run a hose around the back side of the engine for the other turbo
Old Dec 11, 2010 | 08:37 PM
bravolistick's Avatar
this ^^^
Old Dec 12, 2010 | 10:02 AM
LS1NOVA's Avatar
You can use the factory sender location for your oil pressure guage using an adapter. Then use a tee at the oil filter location. Dont worry about long lines.
Old Dec 12, 2010 | 10:30 AM
71 chevy's Avatar
I drilled and tapped the factory sender itself since I was not planning to use it. Use 1/8 npt tap.Then I did a 1/8 npt tee, used two 1/8npt to 4an fittings,and ran two 30 inch an lines to the turbos. Very clean install.
I used the location above the filter for my oil pressure gauge
Old Dec 12, 2010 | 01:29 PM
Novaray64's Avatar
does anyone know the part # for this fitting
thanks
Old Dec 12, 2010 | 02:50 PM
LS1NOVA's Avatar
Google takes 10 seconds.
Speedway 1822268
Old Dec 12, 2010 | 03:04 PM
2165 Turbo Rail's Avatar
I also used the stock sender port for my turbo feed line. I bought the fitting from Speedway motors then used a -4 AN to 1/8 npt fitting
Old Dec 12, 2010 | 03:58 PM
Novaray64's Avatar
Thanks that is the fitting I was looking for
Old Dec 13, 2010 | 06:24 AM
ModularTurbo's Avatar
We make a twin turbo oil distribution block.
It bolts on to the side of the block.
https://ls1tech.com/forums/attachmen...t-100_1297.jpg
https://ls1tech.com/forums/attachmen...t-100_1296.jpg
Old Dec 13, 2010 | 12:24 PM
bowtieman_racin's Avatar
Default oil block adapter
how much is that block adapter? Does it bolt on above the oil filter where people normally drill the stock piece? thanks,
Old Dec 13, 2010 | 04:52 PM
Yes it takes the place of the factory plate that people normally drill and tap.
It comes with new bolts and a new GM gasket.
Both ports are ¼ pipe thread.
It makes it easy to feed you turbos and run a aftermarket oil pressure gauge if you choose to.
Price is $59.00 plus shipping
That adapter that Speed Way sells is a cool piece, but it is hell to get to the back of the
motor to install it in the car.
Old Dec 14, 2010 | 06:32 AM
Default oil block
tried to go to your website on your sig to see if you have any other neat stuff I may need. The link doesn't work for me. I'm definately interested in one of those blocks though.
Old Dec 14, 2010 | 08:22 AM
71 chevy's Avatar
are you serious? it takes all of two minutes do drill the factory block off plate with a 5/16 or 11/32 bit and then another minute to tap it for 1/8 npt.
you can buy a tee for $4 and youre done. whats so hard or disingenious about that?
same thing goes for the oil sender location. this is too easy to do.
http://www.stevesnovasite.com/forums...1&postcount=88
Old Dec 14, 2010 | 09:16 AM
Drilling and taping the stock piece is very easy.
The stock cover puts the fitting at an odd angle,
and wouldn’t work for our turbo placement so
we designed this block to put the fittings where
it would best suit our needs.
I just thought I’d offer it.
