Will the stock crank snout hold these HP numbers with a blower app.
This referring to a cog drive set up??
Mighty mouse, Cobra killer. Are you running billet mains, pinned mains, any thing special for the bottom end
My iron block is stock. Stock caps, no pins and no fill.
I run a factory crank, with GM bearings. Have done a few setups that way with no problems. The GM bearings are way too expensive, I need to find another way...
