turbo?
Old Dec 15, 2010 | 04:52 AM
slowblackbird's Avatar
Default turbo?
looking at doing a turbo setup on my ta and i have found a turbo localy that i can buy but i have a ? about the size since i am new to this i am trying to pick up on the turbo stuff. ok its a percision t76 with a 1.22 or 1.23 ar on a t6 flange, i know the .96ar on t4 flange is more common.
the motor is going to be a stock ls1 with a cam(unknown right now) looking at the epp cam, ls6 intake, 60lb injectors, on a truck manifold setup with hopefully a 4" down pipe and 2.5 crossover pipes on a front mount setup.
just trying to gather parts to get it built and running right now and maybe next year do forged internals and more boost. any info you would like to share would be helpfull and i am sure i will have other questions. thanks in advance
Old Dec 15, 2010 | 06:45 AM
JAX04's Avatar
https://ls1tech.com/forums/forced-in...ifold-kit.html
Old Dec 15, 2010 | 11:08 AM
Yes I have read every build thread in here and I know how to do all the fab work and build the motor but that thread does not answer my question about the ar on the turbo. Just because I do not have alot of post does not mean that I have not read alot of the threads.
Old Dec 15, 2010 | 11:25 AM
PT01GT's Avatar
Call Pricision and see if you cat swap the turbine housing out with a T4. Thats huge for a normal street car.
Old Dec 15, 2010 | 12:17 PM
JAX04's Avatar
please show me in your first post where the question is?? I must of missed it, because i couldnt find. In fact, reading through your post again, it looks like you have a plan, but does not even state that you can do any kind of fab your self.
Hence why i posted that sticky. Chill out.
and also, i highley doubt you've read every build thread in here in just 15 days or less.
Now, im not being a dick on purpose, dont force me too be.
ask your questions, and people will help. But be clear about your question, and you will get better results.
Old Dec 15, 2010 | 12:20 PM
pwrtrip75's Avatar
Wow.... dude you're being a dick.
Old Dec 15, 2010 | 12:22 PM
JAX04's Avatar
Read the rest of my post that i added right after submitting, i wasnt trying to be. Read his respone to me and tell me where i cant respond that way.
I wasnt trying to be, i promise that.
Old Dec 15, 2010 | 03:32 PM
My question is how will a t76 with a 1.22 ar spool b/c I know most run a .96 ar on a car like mine
And I have spent hours on here reading, I use to post under graphicnature look that account up and see how long it has been active just decided to create a account of my own. And sorry I did not state first that I can build things and if you want to see what I have built on my own for starters look where I posted in the new section the yj is all my creation
Back to the point anyone have anything to say the turbo i would apprecate any info it is local, in good condition and cheap thanks
Old Dec 15, 2010 | 05:40 PM
Hank Peabody's Avatar
Nobody gives a crap what you can build he was just trying to be helpful, no need for the attitude.
Old Dec 15, 2010 | 05:52 PM
What kind of hard *** statement is that?
Old Dec 15, 2010 | 05:53 PM
T4 flange will be 100 times more fun on a street car mr. master fabricator.
Old Dec 15, 2010 | 05:54 PM
JAX04's Avatar
lol hank, i was just trying to let him know that i wasnt trying to be a dick. and that i can be if need.
i dont wish too though, lol. Id rather find out exactly what his wants and needs are and do my best to try and help.
i dont like being in E-battles with people. lol
Old Dec 15, 2010 | 10:13 PM
I was going to do a build thread but I know not too now thanks
Old Dec 17, 2010 | 01:25 AM
02_ramair_ta's Avatar
That a/r is going to be a pig... with a stock ls1.. now push that same turbo with a larger motor, and your in the money!!
the 60lb injectors are not going to do you much good, unless you dont plan to make anything over +/- 600hp
Like alot of others have mentioned, read the FAQ sections, and check out the tech info on forcedinductions.com, they also have GREAT customer service, so they are a good place to look for questions like this, and might be able to fit your turbo with a smaller t4 housing, and a/r that would work for your application..
goodluck..
Old Dec 17, 2010 | 04:37 AM
02 ram air thanks for your info and I was hoping for about 600 to 650 on the bottom end I have and I might even add a meth kit to help it out. I understand every thing else mostly just wanted to know about when it would spool that turbo with the 1.22 ar and I think I can change the housing back to a .96 ar which I might do
