80lb injectors = what max WHP range?
Old Dec 15, 2010 | 11:20 PM
Hi Volume's Avatar
Default 80lb injectors = what max WHP range?
I know theres a few variables, but roughly what HP number do 80lb injectors support? Reason i ask is, when i built my turbo 4 cylinder cars, i always bought the largest injectors weather i needed them or not. There is nothing worse than maxxing out your injectors on the dyno at a less than desireable HP number. Or running too small of ones at max duty cycle.
These are the ones in question posted in the link below. I get a deal through this site and these are the largest Hi Imp that they sell. Also, since these are Hi impedance i wont need a controller box or any BS for them will i? I will be using HP tuners. thanks
http://www.atpturbo.com/mm5/merchant...egory_Code=FUL
Old Dec 15, 2010 | 11:30 PM
blue00ZZleeper's Avatar
Whats your setup?
Old Dec 15, 2010 | 11:37 PM
Hi Volume's Avatar
Originally Posted by blue00ZZleeper
Whats your setup?
Stock internal Ls1 (katech rod studs)
6 speed
Ls6 intake
Tr224
PT88
Precision 825hp FMIC
AEM Meth kit
4" DP
Fuel system for 1300hp (crank)
Super light weight chassis. (yes thats a mod for me)
Old Dec 15, 2010 | 11:50 PM
Those injectors will do fine. They should be good for 800+ wheel but fueling on turbo cars all depends on your tune. Dont forget pumps, supply/return line and a RRFPR. Maybe someone with a similar setup will chime in. I say your stock bottom end lets go before you come close to maxing them out lol
Old Dec 16, 2010 | 12:59 AM
Hi Volume's Avatar
Yes i know the stock bottom will max out before the injectors, ha. I have a forged build in the works.
As for fueling i have the magnafuel Pro EFI pump, 10 gal sumped fuel cell, aeromotive pre and post filters with an Aeromotive EFI FPR with -8 feed and -6 return.
Old Dec 16, 2010 | 01:42 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
6 speed
Ls6 intake
Tr224
PT88
AEM Meth kit
4" DP
You did not state what base fuel pressure you intend to run and whether or not you intend to run static fuel pressure or a rising-rate regulator?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Dec 16, 2010 | 07:26 AM
2001WS6Vert's Avatar
To give you some baseline, mine are maxed out (100% duty cycle) moving an almost 4000 lb. car to the time in my sig. I would like to pulley down a notch but I would have to have larger injectors.
Old Dec 16, 2010 | 10:17 AM
disc0monkey's Avatar
remember to compare them to actual rwhp number not SAE. here my car gains about 20rwhp or more in the winter over SAE. for example, while my injector is good for 480rwhp SAE and i make 460rwhp SAE. ill be pegging the injector on a -1000 DA. this is partly why gm gives a big window with injectors. ie. LS3 about 370rwhp comes with 42lbers.
Old Dec 18, 2010 | 04:33 AM
Hi Volume's Avatar
i would assume a static fuel pressure if i am going to use HP tuners? I dont have a FMU and currently when the car was NA i didnt have a vacuum line hooked up to the FPR.
Old Dec 18, 2010 | 04:36 AM
Hi Volume's Avatar
yes, this is where the variables come into play. My car should be at 2450 w/o driver. Soo long at this point with my stock bottom end, the 80lbs will support towards the 750whp range is what im looking for.
Old Dec 18, 2010 | 04:37 AM
Hi Volume's Avatar
exactly, more variables that move numbers around one way or the other.
Old Dec 20, 2010 | 05:24 PM
Louis at GSS's Avatar
with an 80psi BASE pressure, and a 1:1 regulator on Q16, I made 1080 with twin GT35Rs in a M6 Z06. I was at 85% IDC @ 6600 with those injectors.
On Gas, Id expect 77-82% IDC at the same power level.
Old Dec 20, 2010 | 05:34 PM
mike13's Avatar
It really depends like stated on your fuel pressure, if you run the stock pressure of 58psi you should be right at 1000crank.
Old Dec 21, 2010 | 01:35 AM
Blown06's Avatar
8 Second Truck Club
Damn! What pump are you using to support that kind of volume at those fuel pressure numbers? I've heard of magnafuel 4303's not being able to support those hp numbers at the pressures you mentioned. Starting at a base of 40psi is a different story though.
Old Dec 21, 2010 | 06:18 AM
foose04's Avatar
I made 617/623 at 82% on e85. Also run 8an feed, dual walbro255's, 58psi base pessure. Hope that helps.
Old Dec 21, 2010 | 09:25 AM
Twin bosch 044s
Old Dec 21, 2010 | 11:45 AM
Chronicle's Avatar
Irrelevant question:
How is the TR224 working out for your setup? I was planning to get one for a boosted LQ, but I haven't seen too many people do it before.
Old Dec 21, 2010 | 04:19 PM
Defined1983's Avatar
why aren't you in the single digit club if you're doing 9's?
Old Dec 21, 2010 | 04:51 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
I've seen 775+ rwhp with 60# injectors at stock fuel pressure, so you 'll have plenty of room with the 80s, especially with the Meth.
Old Dec 21, 2010 | 06:49 PM
KissMySSo1's Avatar
That's pretty awesome considering E85.
I made 805rwhp with Mototron 60's in my car. Gotta think 80's can support at least 1000rwhp on gas
