QMP T-63 turbo
Old Feb 6, 2004 | 08:13 PM
BlackNite383's Avatar
Default QMP T-63 turbo
Will the standard T-63 turbo that comes with the QMP kit be big enougn to handle a 383 stroker with ported 6.0 heads?
Old Feb 6, 2004 | 08:25 PM
LSs1Power's Avatar
If u are going to run under 10psi yes, but over that i would go with the T74Q or T76. On the their test formula Rob said somewhere that he is almost maxing out the turbo (T76 i think) at 14psi or something like that. U should really look at the T88 since it has a .63mm compressor, but a larger exhaust housing .88 mm which will be even better for ur setup. Im not sure on the exact number though so dont quote me.
Old Feb 7, 2004 | 12:29 PM
Just this morning my buddy said i would need at least a T78. But a D1SC pushes more air than a T76? DAAAAAMN!!
Old Feb 7, 2004 | 12:46 PM
BOO HOO BRIAN's Avatar
PSJ Wannabe & Attention Whore
If you are 12 psi and under the 74gtq would be fine. A 78 would be off the comp map at that low of psi.
How much hp are you looking to make at the tires?
Old Feb 8, 2004 | 01:13 AM
I'm looking for 650rwhp to 675rwhp, but mostly i would like the torque to build early. So the T76 that QMP uses in their upgraded kit will be fine?
Old Feb 8, 2004 | 06:28 AM
cablebandit's Avatar
Why don't you ask Rob? He should know the answers better than anyone here since it is his kit. I would GUESS you are gonna need at least a t-74
Old Feb 8, 2004 | 11:11 AM
BATMAN's Avatar
How do you figure?? Last time I checked a D-1 supports 800hp, and a t-76 from PT&E supports 1100hp.
Later
