More boost?
Thanks,
Robbie.
Thanks,
Robbie.
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I think you can make 750hp at the motor with a 400+ cube motor and the 1900, but I doubt it'll do that to the wheels. Either way you'll be maxed out. I'm betting a cheaper 370 with the 2300 and better heads would make more power. Is money an issue? Do you already have the LS3 block?
I'd just hate to see you starving a nasty 400+ cube motor with the smaller 1900 blower.
