Backpressure - Can big wastegates help?
something similar to this may be helpful for the rear-mount guys. basically what phil said earlier, its dumping before the "bottle neck"
i have almost zero back pressure, instant spool, no boost creep, and can spin +7,000 rpm, with a 76mm rear mount, .96 exh
I have this cover already.
Yes, i will be changing my exhaust around and will also move my wastegates up front. Thanks
http://s1008.photobucket.com/albums/...t=M4H00068.mp4
hey kyle, what size hot and cold pipes do you run?
Currently as a front mount, i run dual 2.5" into a 3" merge, kind of typical i suppose, lol.
and the cold side is a 3" from the compressor to the intake.
I considering doing some smaller ones, like 2" etc. but was told for fabrication purposes as i am def. a novice, it would be easier to to this route.
That and im not making near the power you gents are. lol. But, i will continue to pay attention to yours and phils ideas and testing. Keep up the great work.
Just curious to see what everyone thinks.
