procharger to j-bracket bolts....loctite?
Old Dec 28, 2010 | 03:47 PM
cals400ex's Avatar
Default procharger to j-bracket bolts....loctite?
i was curious if loctite should be used when mounting a P1 to the j-bracket? does anyone know the approximate torque spec of these bolts? thanks
Old Dec 28, 2010 | 04:08 PM
fatmat80's Avatar
I dont know the tq spec, i made it as tight as I could by hand..
Old Dec 28, 2010 | 04:44 PM
Packy's Avatar
I never use loctite on them. You will have to remove them to change the belt out on your S/C or serpentine belt on your car if needed.
Old Dec 28, 2010 | 06:01 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Dont use loctite. As stated above, you need to remove the procharger sometimes, this is not a permanent attachment. Just get them as tight as you can by hand. Ive never had a problem with those bolts coming loose.
Old Dec 28, 2010 | 11:25 PM
blue00ZZleeper's Avatar
X2...no problems with them loosening up. I only use loctite on the pulley bolt (iirc Procharger says to do this)
Old Dec 29, 2010 | 10:57 AM
LS1RedZ's Avatar
I didnt use any on mine. Just tightened the ever living **** out of them by hand.
