Monitoring EGTs on a turbo car
Has anyone done any testing like this?
usually with the GMPP single plane manifold with edelbrock tall elbow at 22psi boost on methenol, i usually see a max of 35deg difference across 8 cylinders with zero corrections.
35 is not much at all for no cylinder trims on the ecus
on one of the ski race boats i built running a autronic ecu i can get them down to as close as 15deg by using the cylinder trims at the boost it runs normally, it runs a 565ci twin turbo big block chev..
I say thing because I built a powder coating oven and built my controller so I did alot of research in PID controllers and Thermal couplers mine for my oven cost 35 dollars and is within .1 degree tolerance for temps between -600 to 1200 deg F but they can be bought to be withing .0001 degree to 2600 degrees
http://www.lightobject.com/10ft-3M-K...uple-P114.aspx
then find a way to hook up 8 or to be able to cylce through the 8 different imputes Im sure I can figure a way to do it with time to design one
i have it logging, oil pressure, fuel pressure, 8 egt's, rpm, diff speed, trans pressure, trans temp, boost and it gets water and air temp etc from one of the ecu's in the car.. it also controls the warning light and the boost
looks pretty good in the car too,
another issue is you need k-type probes that can withstand the high flow environment....I don't think you could get the probes alone for that price...
they retail for about 1k though
The Holley bunches them all up for some reason, including the one that is way off if you look at the values on the left. They are going to address that ASAP but it's a new system with little user feedback but they are working with us VERY closely.
FYI, it says nitrous tunning on top but that's just because we grabbed one of the tables that we weren't using in order to throw in the 8 EGT's without haveing to move stuff around.
Makes sense for serious racers.....but hobby racing seems moot to me. Fun to gather the data, but not much to effect change.
