Monitoring EGTs on a turbo car
#41
I have the altronics redalert standalone EGT logger.
question is what do they read in 1000F...I'm trying to think of a reasonable way to test that temperature...if they are linear, then the difference should remain the same...I don't think most (if any) EGT systems are 100% accurate since they don't incorporate a reference junction (ice water reference, etc)
I'm not terribly thrilled with the design of my probes though...they use a heavily shielded junction which really slows the response time....although in an actual high-flow environment, some of this slow response is mitigated). My system is supposed to do 100 Hz (10ms) sampling which is faster than most response times of TCs. ...I'm going to bring some fine wire K-type TCs home from work (~1ms response time) and put them into the sytem and see if its TC related or logger related. I may custom order some K-type probes from omega...
#44
http://efi101.com/forum/viewtopic.ph...&highlight=egt
Thinking now....I guess lead solder might be a suitable test medium, as it's melting point should be fairly stable and easy to achieve to test.
#45
I asked the same question here some months ago
#46
It would only deposit on the tip if you actually let it solidify on the top. It wouldnt stick if it remained liquid
And given the material of the probe itself, it may not stick even when it cools
#47
If it is a stainless steel probe it will not stick. You can also use a test instument like an Isotech Isocal 6. They can run up to $4000, and there is less expensive test intruments you can buy. You can also ulitise a RTD which will give you a higher level of acuracy but at a higher cost.
