ebay kit, which turbo
Old Jan 9, 2011 | 03:47 PM
pdasterly's Avatar
Default ebay kit, which turbo
I have a 9.1 cr LS2. Pistons can handle 20 psi. Car is an auto and will be daily driven. Probably will never see the track. currently have t76 A/r 1.0 which was what i was told was the biggest turbo to fit under the hood of a 98 camaro. I have a pa racing tubular cross, upper and lower front control arms with solid motor mounts already. trans is built 4L80E
my firebird(347\D1-intercooled) is projected to hit 700 rwhp give or take 50hp. Bird made 550rwp@5500 rpms with P1SC at 12psi, D1 is pullied to max and Im currently waiting for new high amp alternator and maybe aster bracket but the chevy man mod for sure. So far its going to put my ls2 to shame. LS2 project rwhp is 550-600, guessing.
I definatly want a quick spool valve and or bigger head unit
Old Jan 9, 2011 | 04:01 PM
98Camarod's Avatar
With that kit, that's the biggest you can run other than the tc78. It's due to the down pipe. I know there was someone running a 94mm I think with the kit, but they re did the downpipe.
Old Jan 10, 2011 | 01:48 PM
pdasterly's Avatar
what options do I have if my turbos flange is undivided.
Old Jan 10, 2011 | 04:03 PM
98Camarod's Avatar
Divided/undivided isn't the issue. It's the down pipe that limits your selection. IIRC it's a 3" down pipe
