Where to find log manifolds
Old Jan 10, 2011 | 10:56 PM
jdmv8's Avatar
Default Where to find log manifolds
Does anyone have any links to companies that make log manifolds for a LS1? I am putting a turbo in my LS1 Miata but can't find a set of manifolds that will work. I have tried LS1, LS3, and L33 headers and nothing fits. They all come close but just won't work...
The only way to get this turbo to work is with log manifolds. All of the threads that come up when I search for log manifolds are old and out of date.
Thanks for the help.
Old Jan 11, 2011 | 06:37 AM
driven87's Avatar
im curious about a universal log setup as well
Old Jan 11, 2011 | 07:16 AM
LS1NOVA's Avatar
Post some pics of the space your working with and maybe we can figure what fits. The LS4 manifolds may be a possibility, or at least one of them.
Old Jan 11, 2011 | 07:37 AM
robbyredneck's Avatar
a lot of guys just make them or have them made locally. very simple to construct.
Old Jan 11, 2011 | 08:19 AM
mike13's Avatar
JGS turbo can probably make them for you.
Old Jan 11, 2011 | 09:49 AM
IMPATIENT 1's Avatar
here's my log manifold setup, took me about 3hrs to build the logs, another 3 to build the crossover pipe.
Attached Thumbnails Where to find log manifolds-back-coating.jpg   Where to find log manifolds-5.3-1.jpg   Where to find log manifolds-5.3.jpg   Where to find log manifolds-final-exhaust-mockup.jpg
Old Jan 11, 2011 | 10:11 AM
yelo04goat's Avatar
wow is that for a boat?? or a VW beetle??? looks cool as **** for the time you put in to it
Old Jan 11, 2011 | 10:20 AM
dreamls1's Avatar
is there any benefit to using the log over the Stock 6.0 manifolds?
Old Jan 11, 2011 | 10:58 AM
SSinisterSS's Avatar
How is the flow On a log setup like that one posted above?
Old Jan 11, 2011 | 11:37 AM
yes sir, it went into my 300lb race tunnel, its a jetboat
i'd run manifolds if given the chance, i was gna use them but couldnt get the exit angle i wanted or the look, so i had to build what i wanted
flow should be high, i've got 1.75 primaries dumping into 3" logs, tapering to a 2.5 crossover up to the t6 flange, 83mm turbine s480. i had my hotside all thermal coated internally with the nitro titanium coating on the outside to keep the heat inside.
Attached Thumbnails Where to find log manifolds-turbo-engine-boat-right-side.jpg
Old Jan 11, 2011 | 11:58 AM
jdmv8's Avatar
Here are some pictures of the problems...
Driver side with a 5.3L manifold clears and works perfect!
This is the problem. Passenger side with a 5.3L truck header. This is the only issue I have with the headers. If this outlet would clear everything would be perfect...
Clears everything else...
I guess I might have to make a log manifold if I want to put a turbo in this car.
Old Jan 11, 2011 | 12:18 PM
LS1NOVA's Avatar
Look here https://ls1tech.com/forums/forced-in...-kit-pics.html
It may fit.
Old Jan 11, 2011 | 12:19 PM
LS1NOVA's Avatar
Looking at your pics again, the ls4 man. may be too low.
Old Jan 11, 2011 | 12:22 PM
jdmv8's Avatar
Yeah, they look too low.
The truck headers worked upside down but I just don't like the look. Maybe I should just get over it.
Old Jan 11, 2011 | 02:49 PM
bozzhawg's Avatar
Nice, who coated them for you?
Old Jan 11, 2011 | 03:24 PM
JAX04's Avatar
+1
im just curious, ive seen them used with good results, but would like some info as well.
Old Jan 11, 2011 | 04:08 PM
embee performance coatings out in cali, ive herd to many stories about guys having the inside coatings come loose, so i sent it to the best imo so that never happened. dealt with embee several times in the past and never once had an issue.
