Bought a P1SC...What Should I Expect?
Old Jan 15, 2011 | 03:28 PM
tatasta's Avatar
Default Bought a P1SC...What Should I Expect?
Hey,
I just picked up a P1SC kit with the standard dual intercoolers. I plan to run it with my current setup TR224-112, PnP 243 heads, LS6 intake and the rest of the stuff in my sig.
My questions are:
What kind of power/tq should I expect?
I have 33lb@43.5 injectors. Will they be enough?
No dyno in my area. I use EFI Live. How difficult will it be to tune?
I will take the N2O off and sell it.
I expect to run 5lbs of boost.
Thanks
Old Jan 15, 2011 | 03:59 PM
Chronicle's Avatar
Not too sure about a lot of that, but I know that 33lb injectors are not going to be enough. I'd go with either 42 lb or 60 to play it safe.
Old Jan 15, 2011 | 06:30 PM
Packy's Avatar
Get some 60 lb/hr injectors.
Old Jan 15, 2011 | 06:51 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by tatasta
Hey,
My questions are:
Thanks
As has been mentioned, you need to go with larger 60# injectors.
I wouldn't mess around with 5 lbs of boost, I'd go for 7 or 8 lbs. 5 lbs would make your combination seem weak, and would take more rpm to even feel it. 8 lbs should give you approx 140 extra rwhp.
Tuning with forced induction can quickly lead to a broken piston if you're not familiar with the aspects of the fuel and timing requirements. I'd try to find someone with a similar combination that can give you a copy of their tune for starters, and shoot for an air/fuel ratio above 5000 rpm of 11.5/1, and pull the timing back to 18 degrees.
If you need any piece parts to complete your installation, I have most of them listed at this link. http://shop.brutespeed.com/98-02-F-Body_c181.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 16, 2011 | 02:58 AM
68 SS's Avatar
I have a brand new set of 60# motrons I want to sell if you are interested shoot me a PM. I ended up going with 80# these have never had fuel in them.
Old Jan 16, 2011 | 12:45 PM
02LS1ram's Avatar
Don't waste ur time w 42s just go right for the 60s. Listen to bob n go w 8lbs he knows his stuff
Old Jan 16, 2011 | 07:30 PM
tatasta's Avatar
Bob,
Thank you very much for the info. I will pick up a set of 60lb injectors.
As far as tuning, I will post up on EFI Live to ask for a base tune. I run N/A at around 24 degrees and 12.4/1. I am brand new to FI so I will play it safe.
Also, I have a Racetronix pump that runs at about 68lbs. I pulled it out and went back to a stock pump because the Racetronix was difficult to tune for at that pressure. I'm sure I will need the bigger pump. Do you think I will need a regulator?
Thanks again,
Bob
Old Jan 16, 2011 | 09:00 PM
Packy's Avatar
Bob,
Thanks again,
Bob
I would switch back to the Racetronix pump and maybe get a set of fuel rails with an aftermarket regulator rail mounted for better FP control.
Old Jan 17, 2011 | 05:31 AM
LS1Tech Sponsor
Bob,
Thanks again,
Bob
You're welcome!
I agree with Packy, switch back to the Racetronix pump and the regulator will help you to dial back the fuel pressure so you can find a base tune to start with. Bob
__________________
Old Jan 17, 2011 | 10:11 AM
LS1RedZ's Avatar
Yeah, I would definitely go with 7-8lbs like Bob said. Should put you around the 500 mark.
Old Jan 17, 2011 | 08:06 PM
tatasta's Avatar
Thank you for the replies. They have been helpful. Could someone point in the right direction for a fuel pressure regulator?
I'm not real sure of the best way to go
Thanks
Old Jan 18, 2011 | 04:31 PM
LS1Tech Sponsor
Thanks
http://www.nastyperformance.com/default.html
Check with Nate to see what he has that will work for you. Bob
__________________
