MAP sensor
Old Jan 17, 2011 | 09:07 AM
Sweet_SS's Avatar
Default MAP sensor
I'm currently in the middle of my turbo build and need to know if I need to replace my stock MAP sensor? If so, does anyone have a picture of one installed on the intake? I would like to get an idea of how its held into place. Any help is appreciated. Please note, I did try to use the search feature, but like everything else in my life, I came up empty.
Thanks.
Old Jan 17, 2011 | 10:33 AM
MUSTANGBRKR02's Avatar
Yes you are going to need a two bar MAP sensor. It goes in the stock location.
You can buy it here.
http://www.tunedbyfrost.com/products_sens01.htm
Should also get a threaded IAT sensor from a early 90's Syclone or Typhoon. Any parts store will have this and it plugs into your stock harness.
Old Jan 17, 2011 | 10:35 AM
HydroStream6's Avatar
If you are going to go with a speed density tune, then yes you will need a 2 or 3 bar map sensor. If you are going with a maf tune, the stock map sensor is fine.
Old Jan 17, 2011 | 10:54 AM
Sweet_SS's Avatar
Thanks fellas.
Old Jan 17, 2011 | 11:48 AM
LS1RedZ's Avatar
Can you use this 3 bar sensor?
http://cgi.ebay.com/ebaymotors/F-GM-...item5d2a472db4
