Budget turbo build
Old Jan 16, 2011 | 03:53 PM
ffrh911's Avatar
Default Budget turbo build
I'm thinking about buying a turbo kit from my buddy for 250$ brand new. Comes with turbo, intercooler, headers, all pipes but downpipe. I believe it's a 67mm turbo. I'd like to keep the bottom end stock just for now so my ? Is what do I need to get this to run good on my car? I know I need oil lines, injectors, fuel pump, new plugs. Also have a Set of 241 heads that I will be porting and will get new cam, timing chain, etc. So what else do I need?
Old Jan 16, 2011 | 04:12 PM
stoverz28's Avatar
A turbo kit with all that for $250? Sounds to good to be true....
You'll also need a boost reference fuel pressure regulator, and a waste gate and blow off valve.
Old Jan 16, 2011 | 06:51 PM
98TA6.0's Avatar
lets see some pics. is it front mount or rear mount? if its the Egay turbo setup be careful. the turbo is absolute junk andthe pipes are awkward and do not line up right. pm sent
Old Jan 16, 2011 | 07:00 PM
ffrh911's Avatar
Front mount and it is am eBay kit I know he payed around 1,000$ for it at the time.
Old Jan 16, 2011 | 07:40 PM
98TA6.0's Avatar
be careful. those wastegates and turbos are prone to failure. do a search. you will see how much trouble those POS things have given everyone here. but they do work and do well with streetable setup and they retain AC.
Old Jan 16, 2011 | 08:35 PM
ffrh911's Avatar
CANCan you find me a link to some info? I looked and can't find anything.
Old Jan 16, 2011 | 08:44 PM
98TA6.0's Avatar
you can give Xtremedime a holler. he had the Egay turbo kit and is not going with a truck manifold setup.
Old Jan 16, 2011 | 08:52 PM
southpaw0314's Avatar
if i was you i would buy the kit and just use the piping and buy a new turbo and wastegate since i wouldnt trust ebay products.
Old Jan 17, 2011 | 06:29 AM
98Camarod's Avatar
That's what I did and haven't had a problem with it.
You'll need to make your own power steering lines, get solid mounts, enlarge the header bolt holes, and some kits have issues with the return from the waste gate.
I have solid mounts and 42.5lb@43.5lb injectors for sale btw
Old Jan 17, 2011 | 12:31 PM
stoverz28's Avatar
https://ls1tech.com/forums/forced-in...-ebay-kit.html
https://ls1tech.com/forums/forced-in...-wana-see.html
