KY Turbo install
Old Feb 4, 2011 | 07:25 AM
Sweet_SS's Avatar
Another update:
Speed Inc alt and relocation kit installed and wired.
Thanks Nnracing for the parts.
Next
-Pusher fan
-Wastegate
-Exhaust wrap
-2 bar map
-PCM...sending to frost
-HP Tuners
...finally time to assemble the car
Mods following assembly
-Gauges
-Catch can setup
-Fuel
Old Feb 6, 2011 | 07:51 PM
273sunsetZ's Avatar
Nice progress. How was the install? I'll be doing this same kit in a few months.
Old Feb 6, 2011 | 09:26 PM
Sweet_SS's Avatar
The worst of it was getting the oil pan off. Other then that, just some cutting and relocating a few things. You'll have remove your sway bar...if you have the same cross over. Also, your...If I'm correct, the traction control box will have to be relocated. I had to modify my horn bracket and remount horizontal instead of vertical. You'll need to pull up the harness with the alternator wire in it. That will have to be extended for the alt relocation. Its all the small little crap ya know? However, it seems I keep running too stupid **** that needs to be taken care of. Next is my fan and wastegate then I can finish up, but I still need my 2bar map and my PCM sent out. Start up is close.
Old Feb 6, 2011 | 09:40 PM
273sunsetZ's Avatar
the sway bar is coming off anyways and i dont have traction control, but seems like you said just gonna take some time relocating a few things to make it work. I'll be keeping track of your progress
Old Feb 6, 2011 | 09:42 PM
Sweet_SS's Avatar
Sounds good. I will post up my fan install once I get it. Im going with a 14" Summit with a CFM of 1585...draws only 7.90 amps. So I will probably just wire it up to the factory plug. My trans cooler will be sitting next to it on the rad.
Old Feb 6, 2011 | 11:29 PM
Nitroused383's Avatar
That fan wont work well, the stock fans are around 3500 cfm. There is a thread going right now on what pusher fans to order. Two derale 12" fans is the way to go. What did you have to do to get the pan off? Have any pics of where you tapped the pan?
The thread
https://ls1tech.com/forums/forced-in...sher-fans.html
Old Feb 7, 2011 | 08:28 AM
Sweet_SS's Avatar
The thread
The K-member needs to be lowered and the motor pulled up to the cowl to get the pan off. I used this method.
https://ls1tech.com/forums/generatio...-write-up.html.
Pic of my oil pan:
Here's a couple of pics I used for reference.
These pics were found on the forum. Searched and searched until my eyes bled lol. Used was a 1/8 NPT to a -4 AN fitting for the feed and -10AN for the return. As far as the fan goes, the car isn't a daily driver. Maybe its time to go back to the drawing board. I only I have space for one fan.
Old Feb 10, 2011 | 08:55 AM
Sweet_SS's Avatar
Some goodies came in yesterday
Yesterday:
Installed the B&M trans cooler
Wrapped exhaust
Later Today:
Mount and wire fan (Zirgo 16" 3,000CFM...10amp draw)
Run lines to cooler
Install Rad...etc etc
Monday:
Sending out PCM.
Old Feb 16, 2011 | 06:01 PM
Sweet_SS's Avatar
Start up vid, but I don't have a vid camera so I used my cell
Old Feb 16, 2011 | 06:10 PM
273sunsetZ's Avatar
Congrats
you might have already mentioned, but what cam are you using?
Old Feb 16, 2011 | 07:06 PM
Sweet_SS's Avatar
Originally Posted by 273sunsetZ
Congrats
As far as I know, the cam is stock. The guy I bought the car from didn't really say if there was work done to it.
Thanks
Old Feb 20, 2011 | 08:18 PM
  #32
Sweet_SS's Avatar
Say cheese!!!!!
What do you think? I tried to keep it clean with a stockish look...did I pull it off? O0
Old Feb 21, 2011 | 12:41 AM
  #33
Ryans99ls1's Avatar
looks great. youd probably have to be looking for the intercooler to notice it.
Old Feb 21, 2011 | 01:02 AM
  #34
marc97taws6's Avatar
Be sure to let me know how you like this. I'm considering doing an LQ4/TC78 swap into my old 1997 WS6 if I end up buying it back
Old Feb 21, 2011 | 07:33 AM
  #35
Sweet_SS's Avatar
Very true. I'm thinking I might need to do more cutting.
Thanks.
  #36
Sweet_SS's Avatar
Will do.
Old Mar 2, 2011 | 08:28 AM
  #37
Everything turned out great! Is that the 6LE grille? That is the same way I want to do my grille but I wish I could find a grille that uses stock mounts and not the screws so I can cut more out. Keep us updated with results, you going to dyno it?
Old Mar 2, 2011 | 11:10 AM
  #38
Rickys S/C Z28's Avatar
Looks great man!! I told you that you will love it when its done
Old Mar 2, 2011 | 11:53 AM
  #39
52172's Avatar
looks great bro!
Old Mar 2, 2011 | 02:35 PM
  #40
Sweet_SS's Avatar
Thanks fellas. I'm glad I listened and did my research on this build. However, I still have some odds and ends to wrap up, but all-in-all its been fun. The grille is in fact a 6LE Design. Right now the car is being towed this weekend for some exhaust work and I trimmed the bumper a bit and added the BMR chrome rad shroud. I threw on my K&N filter yesterday and I am awaiting my fuel pump and assembly from Lonnie.
Threw the shop light in to show in detail...no neon glow LOL
