Pusher Fans
Old Jan 25, 2011 | 11:25 PM
Monte4ever's Avatar
Default Pusher Fans
I have Spal's dual 11" electric fans that I am rewiring to run as a pusher, but because of space limitations (for my trans cooler) I may have to break down and buy a single pusher. My question is how good are the pusher style fans on a high powered (700+RWHP) Procharged/Turbo application and what size CFM ratings should I look for? The dual fan setup worked great as a puller on my BBC but now the F1A is taking up too much of that space. I may be able to run a large single in front of the radiator if I move it over towards the drivers side; however without a fan shroud will it cool ok? Which position would be best?
Old Jan 26, 2011 | 12:38 AM
KILLER-LS1's Avatar
im running 2 spal 10" pushers and they keep my 723rwhp car plenty cool sitting in traffic
Old Jan 26, 2011 | 08:25 AM
Tally TransAm's Avatar
no problems with mine
dual 12" derale's
Old Jan 26, 2011 | 09:06 AM
trnsfmr99's Avatar
i'm around 550 to 600, running one puller, one pusher "13"maradyne" as the puller, can't remember the brand name on the other, but either one by itself keeps the car cool, unless its 100 plus degrees out in stop and go traffic. the other is a fail safe.
Old Jan 26, 2011 | 09:32 AM
Sweet_SS's Avatar
Not to thread jack, but were you able to wire them up without hacking up the stock harness?
Old Jan 26, 2011 | 10:30 AM
on first attempt i wired them into the factory harness with factory style plugs but they drew too much amperage and didnt work out. kinda a brain fart on my end. following that i added two simple single relay circuits triggered off the factory high speed fan triggers
Old Jan 26, 2011 | 10:39 AM
BadgeZ28's Avatar
If you are pushing through the AC condenser I would say a single would not be enough. I modified the stock core support to allow moving the AC condenser away from the radiator. I installed a 16" Spal pusher directly to the face of the radiator. There is a 12"puller on the passinger side. I completely bypassed the stock fan wiring. I have an adustable aftermarket controller with a relay for each fan. Power comes of the hot post on the driver's side fender.
Old Jan 26, 2011 | 12:10 PM
Monte4ever's Avatar
I was looking into a 16" pusher to free up some space between the intercooler and radiator for my trans cooler. Are you boosted and do you think a single pusher would be enough for 700+RWHP?
Old Jan 26, 2011 | 12:13 PM
Monte4ever's Avatar
I thought about running two fans like this also but I read (somewhere) that two fans facing each other is not a good idea.
Old Jan 26, 2011 | 05:59 PM
BadgeZ28's Avatar
Yes, I have a supercharger but don't make that much HP. I run a LT1 radiator also. Everything I have read says puller fans are more efficient at cooling. Some of the Procharger guys have had cooling problems with the provided 16" puller. Some add a small additional puller. I might be a bit conservative by having two fans but running hot is not a good idea with boost.
Old Jan 26, 2011 | 06:17 PM
koolrayz's Avatar
Two of these and you will be good to go, works for me anyway.
http://www.summitracing.com/parts/DER-16925/
Old Jan 26, 2011 | 07:17 PM
Superman09's Avatar
LS1Tech Sponsor
stock wiring?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jan 27, 2011 | 05:13 AM
Nitroused383's Avatar
What part # are you guys running for the spal fans? Are there any fans you can simply plug into the stock wiring, or atleast buy the stock connection somewhere and splice it in?
Old Jan 27, 2011 | 07:54 AM
Sweet_SS's Avatar
X2. I would like to know this as well please.
Old Jan 27, 2011 | 08:10 AM
Superman09's Avatar
LS1Tech Sponsor
x3
__________________
Old Jan 27, 2011 | 08:45 AM
RICE ETR's Avatar
Turbo Addict
I'm using 12in spal pushers..i'll see if I can dig up p/n. If u are pushing thru condensor, seal up inbetween rad and cond. I put male spade connectors on fan wiring and plugged into factory plugs. Stock rad didn't cut it in traffic with ac on, and ambient temps of 95 or above.
Old Jan 27, 2011 | 09:11 AM
JAX04's Avatar
SUBSCRIBING, good info here, ill probably be needing to do something if i cant modify my stockers to work.
Old Jan 27, 2011 | 12:13 PM
Monte4ever's Avatar
Do you guys think that one big 16" puller with 3000cfm will work without a fan shroud? Also because of the blower it has to be slightly offset to the drivers side. Like BadgeZ28, I was thinking about putting an pusher fan on there to but I don't want them to overlap each other.
Old Jan 27, 2011 | 06:07 PM
trnsfmr99's Avatar
the unknown brand fan is the one that's on the a/c condenser side, acting as the pusher. the other maradyne fan is the puller fan. both fans are technically forcing the air from the front to the back, so yes they are facing each other, but they force the air the same direction.
Old Jan 27, 2011 | 06:11 PM
koolrayz's Avatar
Originally Posted by Superman09
stock wiring?
God no. I use the stock wiring to trigger relays. I run a #10 wire off of the alternater to the relay to power the fans. They each draw over 20 amps
