hooking procharger plenum up to TB (no MAF)
Old Jan 19, 2011 | 09:37 PM
cals400ex's Avatar
Default hooking procharger plenum up to TB (no MAF)
I am trying to find a good way to hook the plenum directly up to the stock TB and bypassing the MAF. There is a slight bend because the plenum sits a little higher than the TB. Is there any good, clean way to do this? I know i can get a 4"-3" reducer but I wasn't sure if that slight bend would cause any problems hooking this up?
Old Jan 19, 2011 | 09:54 PM
02LS1ram's Avatar
Use a coupler on each end n then cut a piece of pipe too length. I was goin to use a piece of 3" exhaust pipe or alumi w a 45deg angle before I decided not to go to SD tune
Old Jan 20, 2011 | 10:23 AM
AFASTYZFR1's Avatar
Old set-up:
