turbo build questions
Old Jan 20, 2011 | 10:26 PM
southpaw0314's Avatar
Default turbo build questions
im planning my build for the summer. in the beginning im gonna stick with my stock block add 317s, and z06 cam. I will be making the turbo system from a c6 manifold and a truck manifold. I want to make 550hp to the wheels with the stock motor. will i make 550hp to the wheels with a mp70? how much boost will i have to run to reach this number? also once i get a forged 370 will i be able to hit 650-700 with this turbo?
thanks adam
Old Jan 21, 2011 | 12:47 AM
TurboS10's Avatar
A MPT76Q (Q 68mm turbine) is more in line with what you want.
Or keep an eye out for a used TC76 or TC78. (F1 68mm turbine)
Either way, they will all be small for a forged 370.
All 3 have a 68mm turbine.
You'll definitely want a 75mm turbine like an HPS or GTS turbo.
The TC's choke in the 650 range an the Q lower than that.
They make a MPT70Q also I think.
buy once or twice........
Old Jan 21, 2011 | 12:08 PM
any other opinions, im trying to learn as much as i can so i only have to buy once.
Old Jan 22, 2011 | 05:41 PM
bump!
Old Jan 22, 2011 | 05:56 PM
Fondle's Avatar
get the MP gt 45
Old Jan 22, 2011 | 06:17 PM
MillsMotorvation's Avatar
Im going to try the MP76, what is a gt45?
