head install with arp 12pt
Old Jan 31, 2011 | 05:32 PM
FMX05's Avatar
Originally Posted by DeltaT
All you did was use the stud as a thread cleaner. Better to use an actual thread chaser since it has channels for the crud and you will avoid damaging an expensive stud. You can get a set of thread chasers for like $15 if not less. Your technique is good though
Jim
Pretty much. There was very little resistance against a small allen key. It was more than hand tight but hand tight was hands with ARP lube all over them haha. If I felt like it was enough to damage the threads I wouldn't have proceeded. Most likely it was a dusting of surface rust left from the block being washed before assembly.
Old Jan 31, 2011 | 07:08 PM
TermnEatr's Avatar
yes it is a iron block I actually tried that same process and they where still really tough atleast tough enough to strip them I ordered the somewhat pricey arp thread chaser so hopefully the you pay for what you get modo will come into play with this cause man is this frustrating
