Recommend me a turbo!
Old Jan 26, 2011 | 04:08 PM
Phil99vette's Avatar
7 Second Club
Originally Posted by yelo04goat
good info... so 2 inch on the crossover
and keep the cold side small too? or 3 in about the norm for cold side?
i plan to do a shorty style on driver with cross over to the pass with a log to the turbo..
3" is probably good on the IC piping. Just use your head on the crossover, use a good transition from 2 pipes to 1, try to have 3" or so of straight pipe into the turbo, keep the sides as equal as possible, WG needs to have good airflow placement.
Old Jan 26, 2011 | 04:15 PM
Nitroused383's Avatar
PT76GTS, GT-4276, GT-4580, ST76 or ST80. Those turbos leave you with more room to grow than the TC76 does. Turbonetics does have some new stuff out, if you give forcedinductions.com a call I bet they would fill you in. The TC76 really seems to choke out around 5500 rpm on a 346. The PT76GTS is a great turbo and hard to beat for it's size, it will have quite a bit less back pressure than the TC76.
Old Jan 26, 2011 | 04:57 PM
IWGF's Avatar
Originally Posted by MaxxMitchell
For what he is doing, untouched manifolds will make plenty of power.
I would be more concerned about the small wastegate on a stock bottom end. The 38mm may only be able to control the boost down to 8-11lbs.
TC76 with a .96 A/R would be a good choice, along with any 76-78mm T4 turbo with a .96 exhaust housing.
You still need to spec out your cold side with a bov as well. Plus you still need to either tune it with the maf, or SD.
I'm hoping I'll be able to run 10ish lbs of boost w/ the 38mm wastegate.
Coldside, I'll have to fab up, but it'll be a frontmount air to air intercooler. The car is a street car.
Car will be SD tuned.
Old Jan 26, 2011 | 05:01 PM
IWGF's Avatar
Originally Posted by nodrok
got a turbonetics t76 with a .96 ar brand new not in box. If interested pm me. I will be running a jgs 50mm wastegate (this was recommended by forced inductions). I Have a slightly different set up though.
I gotta sell my nitrous kit to buy a turbo
Old Jan 26, 2011 | 05:25 PM
IWGF's Avatar
Also guys, my goal for now is only around 600whp seeing as I'm on a stock bottom end motor. Once that lets go, I'll most likely be stepping up to a 408 with a PT88 or something similar.
Old Jan 26, 2011 | 05:37 PM
mr_biscuitz's Avatar
I would go a little bigger than the pt88 with those cubes, just my .02
Old Jan 26, 2011 | 06:24 PM
venom ws7's Avatar
I went with ST80 but I have built 347ci though..
I think for your stock bottom PT76GTS will work awesome..
Old Jan 27, 2011 | 09:30 AM
IMPATIENT 1's Avatar
why not recommend a 83mm turbine s475 or s480 with a 1.1ar t6? wayyy bigger turbine than the tc76.
 Michael S. Palmer
Old Jan 27, 2011 | 03:30 PM
The ST76 and ST80 are basically the same thing as s480 with 83mm turbine, but they are in a T4 foot print. Bullseye sells an S380r that is well worth looking into also.
