Trans cooler in front of intercooler
Trans fluid is a little more hearty that its sometimes made out to be. It doesn't have to be ice cold, or nearly as cool as you want your intake temps. A smaller cooler might still be able to keep you in a safe operating range. If you have a high-stall converter though, you will need some significant cooling.
Also, does your radiator have a transmission cooler built into the side tank that you could use?
Do you have an aftermarket high-stall converter?
Just me thinking outside the box!
My guess would be because he can't fit a puller but I'm brain dead so what would I know?
I posted here to help Monte4ever out with his question. I provided a logical and well thought out answer that would have steered him in the right direction. If anyone has a logical and well thought out reason why my idea would have steered him wrong, I'd love to hear it. Enough with the "we make mo powah" and "may as well just leave it all stock" crap though, really. Neither of you had any ideas for the guy.
As far as room for a puller I am using a C5 front accessory drive system which puts the F1A in the way for dual's. I do have room for a single but I'm set on running dual's.
I decided on placing them 1 to 2" horizontally to the ground behind the front bumper within 12" from the stock plastic air-dam (air diverter). There should be plenty of air flow there.
I think you'd be better off with a single pull fan as opposed to 2 pushers but you may as well try it how you have it and see if you have any trouble keeping it cool, seeing as it sounds like you already have it together.
moving on to the topic i was not a fan at all of putting my cooler in front of anything on my car is i came up with this and i must say it has worked out way better than i could have hope it would
i got this cooler of jegs its a bar and plate type good for 30k gvw, it came with a 600cfm fan, and take AN fittings i have -6an line on it now. the fan blows to the right so there is no fighting for air flow with the rad. or innercooler. all the fans come on at the same time. i have never seen over 150degs even at the track sitting.
in this pic you can see the trans cooler on the left and the bottom of the innercooler on the right
top view
hope this helps
