Tried to dyno 383/ST80 with 4200 stall
I put my car on the dyno last weekend and it didn't go as planned, it looks like the converter couldn't hold the torque. The green line is the boost 16.9lbs. No tire spin, the 60lb injectors where at 80% duty cycle at a boost referenced 74psi fuel pressure .
![](http://i247.photobucket.com/albums/gg131/keith42_01/img016.jpg)
It only made 445/410 hp/tq, when I checked my datalogs there was over a 800rpm difference in rpm to wheel speed at 5800 rpm. I good indication is as the boost starts really climbing the graph has all those up and downs like wheel spin. Looking at my injector duty cycle it should be in the 700rwhp range.
It's supposed to be a 4000-4200 stall but this was before the 383 and ST80, it was spec'd for much less hp and tq.
How is it on the street? It's hard to tell because of the cold roads but kind of like it has a rubber driveshaft is the best I can discribe it. What's interesting is the boost comes in really high in the rpm on the dyno but on the street it builds boost completely different, much earlier.
Yep, blowing through the converter. Get a converter rated for the application. LOL Mine was rated at 550hp. It slipped at 670 and the ramps on the graph loked just like that. I am working on getting a new converter now...be ready to pay some $$$$ for a good converter.
yeah a i tried to dyno on dynojet while using a super cheap summit converter..... I knew i was blowing through it badly on the street but the dyno really made the car/converter do some weird stuff
excited for the new PTC and actually put the power to the ground
That is just what a Mustang dyno run looks like when you abort the run before the end of the test window. It is still recording as the engine decels hence the power readings jumping back and forth between 0 and whatever it was making on the way up. It doesn't show anything at all about your torque converter.
My car made a whopping 520 rwhp (previous best was 470rwhp) on a Mustang dyno and runs low 10's with a 3850 race weight. We also had to apply about 8000lbs of load to accurately simulate street conditions with spoolup.
I'm glad I learned long ago to never believe dyno HP numbers and to only use them as tuning tools. I've seen several 700+ rwhp dyno charts that produce 12 sec time slips in the low 120mph range.
well a dynojet would be different than what you used. The rollers are 5k lbs+ and it made the car act *** backwards compared to the street
on the graph power would hit early but stay low and constant. The engine would just sit at one RPM while the tire speed would slowly pick up
and word to zombie, dyno #'s don't mean dick
my rpm would flash high and just sit there, and wheel speed came up slowly after
my power curve came quick from the flash but stayed low and flatish
