Fast Or Vic Jr ?
Old Jan 26, 2011 | 06:54 PM
DAS1998's Avatar
Default Fast Or Vic Jr ?
408 with D1SC... Can't decide which is the way to go? Street Car and really do not want to cut it up, does anyone know how much modification is need with the GMPP? Researched all kinds of threads but still seemed like nothing has been proven to be better or worse. Opinions are apperciated.
Thanks
Old Jan 26, 2011 | 06:59 PM
JimS's Avatar
Same type questions here. Subscribed.
Old Jan 26, 2011 | 07:04 PM
DAS1998's Avatar
If the gmpp intake would not require cutting the cowl that seem to be the way. From what i have read people end up butching the cowl and putting a accufab on and having good results. Being FI they all will work but which is producing the most. On average i would tend to think most people are not going to far past 7K. However i could be wrong.
Old Jan 26, 2011 | 08:02 PM
Brigger18's Avatar
It always goes back to the old trustee LS6 intake. I have a fast 90 on mine tho. Fits like stock, no cutting needed.
Old Jan 26, 2011 | 08:07 PM
DAS1998's Avatar
Your right but i am using L92 Heads
Old Jan 26, 2011 | 08:11 PM
boostedLSX's Avatar
Depends what your looking for. With a gmpp or vic jr intake there less efficient in the lower rpm ranges but have a little better gains in the 6000+rpm range over the fast. The fast however is better in the low ranges. I read a comparison between the vic jr and the fast 90mm. The fast was better than the vic jr until about 6400rpms then the vic jr started to take over. But like stated above i dont think your going much higher than 7000rpms. and now that the fast is a 102mm who knows? I've also seen people running up to 18lbs of boost on the fast intake and it has been fine. no deflection. Now if this was a 25lbs boost or something that redlined at 9000rpms i would say gmpp or vic jr. But if you want to drive around the city and have plenty of low end power i would say fast.
Old Jan 27, 2011 | 06:21 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I don't see you making a bad decision if you went with either the Vic Jr or the FAST. I had a Vic Jr on my 408 with an F-1A, and it did a great job. For basically street use I'd probably go with the FAST. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 27, 2011 | 09:40 AM
DAS1998's Avatar
Hey Bob, thanks for getting my polished plenum to me so fast. You are definatly the ProCharger Guy. Do you know if the GMPP is any shorter the the VIC?
Old Jan 28, 2011 | 05:32 AM
LS1Tech Sponsor
Thanks, I appreciate it. It seems to me the GMPP is around .38 shorter but I don't remember the exact specs. Bob
__________________
Old Jan 28, 2011 | 06:34 AM
JimS's Avatar
Just so you know... I've been out of the game for a lot of years and have a ton to learn (when I was last active Garlits had the record at 8.31 and 181 mph!) and these forums are really wonderful.
Your participation in this thread and others like it have certainly acquired my attention and during this next year, as I start putting together the parts I need for my 390 ci Procharger F series build, you'll be high on the list of people I'll be contacting. Thanks for being a sponsor and for being an active participant in the forum.
