Meth vs n2o
Old Jan 29, 2011 | 07:01 PM
phatasp's Avatar
Default Meth vs n2o
This is probably a dnmb question but here goes. If meth is supposed to cool the intake temps would,nt a small shot of n2o do the same thing. Ok got my suit on fire away
Old Jan 29, 2011 | 07:04 PM
Sluggish's Avatar
Meth not only cools, it raises the octane of your a/f mix and acts as extra fueling.
Old Jan 29, 2011 | 07:11 PM
05HD's Avatar
Meth, or more specifically meth and water, provide intake temp reduction AND combustion temp reduction. Nitrous oxide provides intake temp reduction but, since it is an oxidizer, it actually increases combustion temperature. Hopefully, this information makes it a bit more clear what to choose for an effective detonation suppressant.
Old Jan 29, 2011 | 07:50 PM
phatasp's Avatar
Thanks, did,nt think about the combustion, I was just thinking about the intake temps.
Old Jan 29, 2011 | 08:50 PM
MIGHTYMOUSE's Avatar
they both cool, but one is fuel and one is air. gotta decide which one you need.
Old Jan 29, 2011 | 09:50 PM
cbloveday's Avatar
I went throught the same dilema earlier this year. I went with small shot of nos vs meth. Nos was an easier install for me. I have access to 100 unleaded so fuel was not the issue for me.
Old Jan 30, 2011 | 12:55 PM
trnsfmr99's Avatar
i had the same question, but i've decided not to do neither one. if my car can't perform at 15psi the way i need it to, i don't need to have it (but that's just me)
Old Jan 30, 2011 | 02:05 PM
kikass_z28's Avatar
I wonder what the temps would look like if you spray both
Old Jan 30, 2011 | 02:29 PM
L-EATER's Avatar
11 Second Truck Club
I like the way you think!! And maybe add some of that nitro-methane additive in the meth tank....
Seriously, I was using a dry shot of nitrous way back in like 2003-2004 to try and cool my IATs. I was running a non intercooled Whipple and was seeing some 200+ temps. The juice didn't drop the temps near as much as I expected-if I remember right it only helped maybe 30 degrees or so (and I was spraying across the sensor)
Old Jan 31, 2011 | 03:43 AM
crashly's Avatar
why dont you just spray M5 methanol ....???
