1500HP Build: which TB?
Old Jan 30, 2011 | 08:42 PM
dreamls1's Avatar
Default 1500HP Build: which TB?
Will be running a Vic intake. Should I go with the fast 92 or 102mm TB?
Old Jan 30, 2011 | 08:53 PM
kikass_z28's Avatar
What's the diameter of your cold side?
Old Jan 30, 2011 | 09:11 PM
dreamls1's Avatar
Have not made it yet. 3"?
Old Jan 30, 2011 | 09:24 PM
Phil99vette's Avatar
7 Second Club
I use a 105mm on my motor, probably wont make a big difference but I would go with a 102mm TB. Get a spacer and have someone work the plenum to equalize the airflow distribution, cut corners now and you could be buying pistons. Off the top of my head you probably want to use 3.5" tubing.
Old Jan 30, 2011 | 09:30 PM
dreamls1's Avatar
Thanks Phil, you think 4" is to much?
Old Jan 30, 2011 | 09:34 PM
7 Second Club
4" is just going to slow down the velocity, not really needed at 1500hp.
Old Jan 30, 2011 | 09:45 PM
dreamls1's Avatar
102mm it is
Old Jan 31, 2011 | 04:52 AM
Fireball's Avatar
I ran a 90 with no issue...
Old Jan 31, 2011 | 10:33 AM
98Z28CobraKiller's Avatar
Restricted User
We run a 4" pipe from the IC to a 90mm TB (which is 4") on LS2Formula's car. No lag issues.
Old Jan 31, 2011 | 10:57 AM
Fireball's Avatar
the OD of the TB is 4" but 90mm = 3.5" ID (at the blade)
Old Jan 31, 2011 | 12:56 PM
93formto98T/A's Avatar
I'm running a 92mm TB with 3.5" plumbing.
Old Jan 31, 2011 | 10:13 PM
dreamls1's Avatar
humm, would it be ok to go with the 102mm and the 3.5 or stay with the 92mm
